January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 04-28-2013, 03:45 AM
renovationinnov's Avatar
Cobra Make, Engine: venom motorsports /ls1 auto
Exclamation radiator angle
hi all
i have a custom made radiator which was made by venom motor sports at an angle of 38 degress LAY BACK
my question for help is can the suction /input to water pump from radiator be above the water pump in take & still be affective to cool
i have an ls1 & the radiator is got the output /suction on left so to get the pipe to the righthand side i will have to make a pipe to duct it to the water pump BUT the chassis i have uses the cut down cross member from a jag & the chassis has a box section just above the crossmember so i have to go under this bar then 90 degree up to the in take of the water punp OR OVER THEN DOWN TO THE WATER PUMP BY 50MM so help again
ROB
not all your babies are your children
Rate This Thread:
