Old 09-16-2013, 03:57 AM
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
Default Bumpers Overriders
Hi,
I'm looking for some ideas on where to locate my bumpers and overriders.
My Cobra doesn't have the holes or the brackets. Can anyone take a few photos of where the holes and some dimensions on where they go? How does the front bumper mount to the overrider?
Nathan
Old 09-17-2013, 02:08 AM
renovationinnov's Avatar
Cobra Make, Engine: venom motorsports /ls1 auto
Nathan ive just done mine so I,ll send you some pics tonight
rob
not all your babies are your children
Old 09-17-2013, 11:07 PM
David Hodgson's Avatar
Just make sure the rear bar is not mounted too low. You want the top bar at least level with the boot handle or you run the risk of jagging the over riders on steep driveways etc. Especially on droopy ar$es like G/Force and RMC.
The front hoop has flat bar welded at each end which bolts to the side of the overider.
SLIPRY
Old 09-18-2013, 03:01 PM
Seven, have you got a rear bar yet? if not, I took some measurements off my bar last night. This was originally a DAX bar, not sure if they are all made the same.
Mouning hole centres are 790mm x 58mm
Mounting tube on bar 13mm I.D
Main bar pipe 25mm O.D
Upper mounting tube
centre from top of bar 35mm
So you would drill your top holes 35 mm below the highest point of your bar, and two more 58mm lower and 790 mm apart.
Holes should be large enough for the mounting bar and body grommets.
Hope that makes sense.
SLIPRY
