Like Tree3Likes
  #41 (permalink)
Old 02-18-2014, 05:56 AM
Cobra Make, Engine: Inj 5lt Windsor, T5, Jag Rear
Send a message via MSN to AC427LSX Send a message via Skype™ to AC427LSX
Ok, yes, I found this online, this is exactly what the front end looks like, so crown it is..
Would be interested to know others who have this front end and what mods they have done to it, to make it any better.
  #42 (permalink)
Old 02-20-2014, 01:30 PM
David Hodgson's Avatar
Sly,
I haven't modified mine as yet as it hasn't been begging for it. I’m running the original front springs cut down by 1 coil with Koni adjustable shocks, HQ disc’s and callipers and no sway bar.
The biggest down side is the slow steering, much slower than a rack & pinion. In the early days I toyed with fitting a power steering box to it, which is a faster ratio, but didn't want the eyesore of the pump and hoses, so it never happened. I think though I will graft a rack and pinion in. There's two ways to achieve this; either a suitable standard style rack with tie rods picking up the Ackerman arms or there's kits out there for converting Mustangs etc in which you retain the original tie rods and drag link. The rack then acts directly on the drag link. This retains the original geometry and bump steer etc.
I have played with different geometry and found that about 2 deg neg camber with a bit more caster worked well on the track. Any more seemed to play up on the street, unduced bump steer and wander.
Have you got vented disc's or the original 13mm solids? Later Crowns (MS85) had 20mm vented disc's, but HQ-HJ disc’s and callipers are a relatively easy swap. This gives you a thicker, 25mm vented disc and wider choice of aftermarket discs and callipers and also changes the stud pattern from Ford (4.5”) to match the Jag rear (4.75”). I can let you know details if you like.
You could go all out like Rotax98 on this forum with fabricated control arms, coil overs, different stubs etc, but that’s just given him a bunch of grief. He may have sorted it by now, I haven’t seen him since ’12 Nationals.
Not sure about that VIN number. The original Toyota chassis number should be stamped on the drivers side of the cross member just below the upper control arm mounts (looking into the engine bay). It should read MS65#### or MS85####. Those first 4 characters are the model number.
I'm also curious where the chassis has been shortened. The early ones simply took a chunk out of the side rail. Mine has the bulky steel pressings where the trailing arms mount removed. this gets the seats down to the correct height, and best lends itself to the Jag rear end.
SLIPRY
  #43 (permalink)
Old 03-11-2014, 12:27 AM
Hi David, thanks for the reply,
After doing a fair bit of driving over the last few weeks and speaking to my Chassis guy I have decided to give the front the chop, we are looking at cutting the front off where the Crown front end was stitched on and building custom front rails and putting a pre built IFS & power rack on it, as I am also putting in a LS engine this should make everything a lot easier.
I'm currently looking around for a IFS set up, if anyone knows of any good ones please feel free to post the details and any links.
  #44 (permalink)
Old 03-11-2014, 02:04 AM
Gav's Avatar
Gav Gav is offline
Why not approach one of the existing cobra builders and buy a front clip?
AC427LSX likes this.
Powered by Cu
  #45 (permalink)
Old 03-11-2014, 04:32 AM
750hp's Avatar
Gav's idea is a good one, and it would allow you the chance to do some initial homework by seeing whose might be easiest to adapt.
Just to throw a long/shot alternative your way, my Dad (Donunder here on CC) bought a bolt-in front end from the States for his Arntz:
FAST CARS, Inc MGB IFS
It's a beautiful front end, but for all of your necessary fabrication work I'd follow Gav's suggestion.
Craig
  #46 (permalink)
Old 03-11-2014, 04:37 AM
Aussie Mike's Avatar
You might want to talk to Martin at Kenmer. On our recent shed run I was admiring the work he had done grafting his own design front one onto a Bongalias chassis. This originally used a cut down Jag front cross member. The new front end looked very nice in there.
Mike Murphy
Melbourne Australia
