11Likes
04-07-2014, 03:44 AM
qld
ls1 wont throttle on
started the cobra on the weekend to clean out the garage
it wont idle ,then it would
then it wouldn't run other than idle
it only back fires at full throttle then dies ,but restarts straight away
as I did change the battery out & left it out for a couple of days
so is it learning again
or has the computer gone in to limp mod
it has the standard computer for the motor or do I needed to find someone with tec 2 to check it out
any help will be great
rob
04-07-2014, 04:55 AM
qld
Cobra Make, Engine: Kirkham 427SC 482 Cammer
It's a Holden that's how they run
04-07-2014, 05:18 AM
TAS
Cobra Make, Engine: ?????
Nice try Dave
Where is your first drive video??
04-07-2014, 05:28 AM
VIC
Rob, I often disconnect my battery and it starts and runs perfectly after reconnecting.
My L98 originally ran rough and we traced it to a misfire due to a badly wired injector plug. This showed up as an error code when it was scanned. So that's where I'd be starting - check for fault codes.
vic
Have you disconnected anything?
MAF or TPS sensor?
If not, power off the PCM and try again.
It might just be feeling unloved
Powered by Cu
04-07-2014, 07:45 AM
qld
Originally Posted by Tonus72
Nice try Dave
It's coming it's coming I've been busy with crappy work.
04-07-2014, 04:49 PM
Vic
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
My money is on the MAF sensor. Check the plug connection, make sure the MAF is seated properly and also clean the MAF. See if that helps.
www.paintwerks.com.au
04-07-2014, 06:26 PM
Cobra Make, Engine: Pace 427 SC-S, 351W
Rob, I would probably watch Welcome to The NEW EricTheCarGuy! - Eric The Car Guy- Stay Dirty! and look at rough idle for your issues. He goes through everything step by step. Perhaps not 100% accurate but he seems very logically in his approach and at least explains things in detail i.e. "I do this because of this" at limits his opinion.
04-12-2014, 03:41 AM
qld
well to day I pulled every sensor & connector off , cleaned &refitted ...found a almost broken wire at the connector cleaned out the throttle body & idle step motor
now we have idle
GAV ..cleaned all plugs with contact cleaner seams ok
PAINTWORKS cleaned the mafs with carbie / throttle body cleaner ..so tomorrow ill take it for a run up the street
PIGSEAR did clean all then watched his video it now idling
SO NOW JUST TO GIVE IT A RUN & see what happens ??????????
thanks for all the in put
ROB
04-14-2014, 01:25 AM
NT
How did it go?
Cruising in 5th
04-14-2014, 01:33 AM
qld
he is still standing on his head
04-14-2014, 03:34 AM
qld
BOX HEAD its rained every day since I last posted
DAMAGE my head hurts
fired it up & now have fuel smell & a white ish plume around it while running
rob
04-15-2014, 07:19 AM
qld
The white plume is probably hazy eyes from too much blood in your brain from standing on your head mate
04-15-2014, 07:39 AM
Q
Originally Posted by renovationinnov
...now have a white ish plume around it while running
rob
Rob that's great news. The car's not yet finished and it's already going supersonic. Impressive! Pilots have nothing on you...
Craig
04-16-2014, 03:40 AM
qld
Craig I wish but I found that I was turning the alternator to slow [ belt slipping ] the belt tensioner stripped its thread [tucker made so new one being made
but now the alternator shows 16 amps out put then turn it off & restart & its back to 14 then 12 so alternator might have a regulator fault causing me problems going to get it tested tomorrow
rob
04-19-2014, 04:25 PM
qld
still have some issuesnow it seems to be over fueling
does anyone have a dbo11 scanner that I might borrow or buy
as the repco / super cheap ones seam abit dear for them as $240 & I have seen them on ebay for less
rob
05-30-2014, 05:30 PM
qld
just an up date ... problem solved
took the cobra to POWER TORQUE PERFORMANCE brendale to see if it was a tune problem ,, well & behold it was a maf sensor at the back of the manifold that had no power so no signal
rang the harness supplier , he explained that some harness that were done by his employees they switched the plugs on the blue side of the ecu plug 48should be in position 47 & a feed [orange ] 4amp was to be in 48 position
so we did this & found that the sensor had 12 volts to it so it was buggered & replaced
then refired up as if ti was just out of the box
now dyno tuned & maffless as well yehhaa
starts like a cobra should ,,, thanks to all .. now lane change test then rego
cant wait till Wednesday at lakeside
rob
05-30-2014, 06:00 PM
VIC
Rob, that is great news - its often the little things that cause these problems. (You'll luv the LS1 its a great unit) :-)
What sort of Rear Wheel KWs did you end up with? My stock unopened LS1 does 235RWKW
Cheers Gregg
05-31-2014, 06:02 AM
qld
Gregg did a just abit better but not much
yep haven't driven it much yet but cant wait till Wednesday for the lane & adrive around at lakeside raceway
they did a power pull on it as well to 197km /h it did first run at 15.9 with maf & standard tune then mafless tune 13.9
this is done at idle to 197km/h as per 1/4mile run .iwas told
05-31-2014, 07:25 AM
Vic
awesome stuff, get some video from Lakeside!
I don't know what meth that dyno software is using, but with 230+rwkw in a Cobra you will pull a low 12 easy and if you can get traction then elevenses!
Ben in AU
