Like Tree115Likes
  #141 (permalink)
Old 08-13-2014, 07:40 AM
Hail427's Avatar
Cobra Make, Engine: Pace 427CC 3UZ FE V8
Its not a good angle of the radiator fitting area but it shows the distance
of engine to the radiator support fixture so there's plenty of room from about
half way below the engine as scoop takes the top half, an air box on lower
right side should be easy, appreciate any ideas as Donunder mentioned
it might be a good time to ask Craig to implement.
[IMG][/IMG]
Laner and itempany like this.
parts pile until the first start then it is a car
  #142 (permalink)
Old 08-13-2014, 07:42 AM
Hail427's Avatar
Also I`m thinking about stripes any ideas?
[IMG][/IMG]
  #143 (permalink)
Old 08-13-2014, 07:54 AM
Hail427's Avatar
Another angle on the front radiator support to engine distance.
itempany likes this.
  #144 (permalink)
Old 08-13-2014, 05:47 PM
sambo's Avatar
Coming together nicely Hail. Just curious, how are the front control arm mounts located in the chassis, a threaded insert of some kind? They don't appear to bolt right through.
  #145 (permalink)
Old 08-14-2014, 03:49 AM
400TT's Avatar
Hail427, I was assuming you would draw cold air from underneath the car directly to the rear of the alloy ducting for that scoop. You could just come straight out of your throttle body at the front of the engine, directly vertical and create an air box with pod inside that draws from the bottom. We do this in some of our mid-engine cars and it works a treat.
Solid machined alloy crush bush that goes through chassis tube and welded. Bolts go all the way through. Expensive considering the number of bushes we end up installing in the chassis, but we wouldn't settle for anything else.
Tonus72 likes this.
www.absolutepace.com
  #146 (permalink)
Old 08-14-2014, 03:56 AM
sambo's Avatar
Thanks Craig. The intake you describe is exactly what Kenmer provides. Mine is also ducted under the oil cooler so as not to draw hot air off the road surface.
  #147 (permalink)
Old 08-14-2014, 04:00 AM
400TT's Avatar
We actually have a cold air intake system as an option that draws cold air from over the top of the radiator and suits all the front mounted throttle body engines - all GM, Ford Coyote, Toyota 1UZ etc. Even fits a giant oval pod filter to suit the big HP Supercharged engines like GM LSA/LS9, Supercharged Coyote etc.
Tonus72 likes this.
  #148 (permalink)
Old 08-14-2014, 02:35 PM
Hail427's Avatar
Hi Craig thanks for the update its just a shame im not in QLD I would have been in your shop constantly, can you send some pics if you have any as i`m
trying to see the best result as maybe later supercharging would need modification, which system would you suggest with front type supercharging?
  #149 (permalink)
Old 11-25-2014, 10:56 PM
Hail427's Avatar
Hi all just adding some pics, and if its not to early Merry Chrismas to all!!!
Craig marked out where to cut one line was parallel to bonnet edge,
one was tapered making for a narrower cut, I went with Craig`s advice and chose the parallel cut.
  #150 (permalink)
Old 11-25-2014, 11:01 PM
Hail427's Avatar
  #151 (permalink)
Old 11-25-2014, 11:08 PM
750hp's Avatar
There's no turning back now!
Craig
  #152 (permalink)
Old 11-25-2014, 11:24 PM
Hail427's Avatar
  #153 (permalink)
Old 11-25-2014, 11:26 PM
Hail427's Avatar
Sorry uploading slow tried cropping still slow there is about 9 pics.
  #154 (permalink)
Old 11-25-2014, 11:27 PM
Hail427's Avatar
  #155 (permalink)
Old 11-25-2014, 11:30 PM
Hail427's Avatar
  #156 (permalink)
Old 11-25-2014, 11:39 PM
Hail427's Avatar
  #157 (permalink)
Old 11-25-2014, 11:43 PM
Hail427's Avatar
  #158 (permalink)
Old 11-25-2014, 11:45 PM
Hail427's Avatar
  #159 (permalink)
Old 11-25-2014, 11:50 PM
Hail427's Avatar
  #160 (permalink)
Old 11-25-2014, 11:52 PM
Hail427's Avatar
boxhead, mate and itempany like this.
