3Likes
Post By deano59
Post By Rossba
Post By PeterAllen
08-12-2014, 02:12 AM
NSW
Bonding rubber to rubber?
I'm using rubber extrusions to make a few weatherproofing pieces. I have purchased some "self vulcanizing patches" off eBay which I hope to use but there are a few point where these may not work out.
Does anyone, including any old cobblers, who is aware of a product or technique which will bond rubber to rubber. The joins will not be under much load but they need to be waterproof. Thanks.
08-12-2014, 02:26 AM
VIC
Sticking rubber
Super glue bonds rubber instantly and is waterproof.
Bryan
VK3KDN
08-12-2014, 02:37 AM
Vic
Yep superglue, also Clarke Rubber sell a glue which works on rubber, I suspect it may be the same active ingredient as super glue.
Ben in AU
08-12-2014, 02:47 AM
qld
well when we bond rubber to rubber I use shoe goo from any hardware [ bunnings ] works like gelgrip but only bonds rubber
08-12-2014, 03:45 AM
best is vulcanizing under pressure and temperatur. At home not so easy.
Weatherstrips today are made of EPDM. There are not so many self vulcanizing products for this Polymer, so...
best at home is the cyancrylate glue ( fast glue / superglue?). Not 100 % waterresistance, but for our use in an cobra almost OK
cheers,
Frank
08-12-2014, 04:42 AM
sa
sikerflex once that goes off you will never pull it apart
08-12-2014, 05:47 AM
At work we use a product called SC 2000 two pack adhesive sticks rubber to almost anything including it self
08-12-2014, 07:49 PM
Sikaflex 11FC
08-12-2014, 08:27 PM
Vic
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
Yep...Sikaflex will work a treat. Just don't get it on your hands!
Otherwise, Wurth sell a Rubber Cement which works well too.
www.paintwerks.com.au
08-12-2014, 08:59 PM
NSW
Originally Posted by Paintwerks
Yep...Sikaflex will work a treat. Just don't get it on your hands!....
Are you referring to 11FC specifically?
Originally Posted by 07cob
Sikaflex 11FC
Could you elaborate a little on why you are recommending it, thanks.
I tested Sikaflex 252 I kept stored in the fridge. It was useless!
I couldn't find it available under 1kg package.
08-12-2014, 10:04 PM
What about this 3M product
3M 8011 weather strip adhesive
Have not tried it but it seems to be the right glue for what you are doing
08-12-2014, 11:28 PM
Don't let it set in the gaps of your fingernails, thinking you can peel it out in one piece later on.
I did that about 10 years ago, one nail has never been the same. Doctor couldn't give me an answer either.
08-13-2014, 01:11 AM
Vic
Loctite make a special rubber glue that has been the best I have found so far.
It has a primer spray also for better bonding.
It is designed for joining o rings when needing to make them up.
Ross
08-14-2014, 09:31 PM
NSW
WOW... Thanks. I tried Loctite 406 and the test results were fantastic.
My thanks to others who posted, the super glues were close to the money but nowhere near a good as the Loctite 406.
