January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Like Tree1Likes
  • 1 Post By albanycobra
Old 09-12-2014, 06:51 AM
Default Wolf 3d maps
Does anyone have a fuel and ignition map for a 302 HO Windsor running a wolf 3d ECU?
Old 09-12-2014, 08:09 PM
albanycobra's Avatar
Hey Mate
I think i have a few maps but i used a dual sync crank sensor so may not work with your set up.
SparkyWA likes this.
Old 09-13-2014, 01:11 AM
Just want to check we are in the ball park before sending i. For a dyno tune.
Old 09-14-2014, 07:36 AM
Hey Mate ,just realised your motor is a stocker, my maps are for 8 stacked modified motors running 6al Msd and dual sync dissy. i remember the timing required was very different for the 8 stack and also the tune is only a TPS tune ,no map. I think they would do more bad than good, better telling us what's wrong with your tune and we can help out.
Dave
Old 09-15-2014, 04:12 AM
Problem is a huge flat spot when going from a low steady throttle to half throttle.
Idle is poor and sometimes stalls.
Old 09-15-2014, 04:40 AM
Easy. for the flat spot...go to accel enrichment and increase until the flat spot goes away.just adjust then drive and adjust, make sure you savea copy of your current map so if you mess it up you can reload and start again....Also check your ignition timing has enough advance. For idle make sure the motor is running about 900rpm and adjust the idle mixture till you get a smooth idle.
Old 09-20-2014, 04:10 AM
We'll you would never believe it Albanycobra but the acceleration enrich didn't work!
By pure fluke I have discovered that fuel vapour from the tank breather canister was making its way into the manifold, condensing and finding its way to the MAP pressure sensor in the ECU! I have cleaned all the lines and blocked off the emission canister and now it goes better than ever!
Rate This Thread:
