November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree4Likes
  • 3 Post By Wazza
  • 1 Post By leroy17
Old 10-11-2014, 08:44 PM
renovationinnov's Avatar
Cobra Make, Engine: venom motorsports /ls1 auto
Talking how many cobras run foot well vents
hi guys just wondering how many of you are fitted with foot well vents & where are most fitted as I have no room above the foot boxes & only place to fit is under the brake booster so it will blow air at my feet but at the bottom of them not from the top down
any help
ROB
not all your babies are your children
Old 10-11-2014, 09:09 PM
sambo's Avatar
I doubt it matters whether high or low. You still get the air flowing through and taking with it the heat radiating into your foot boxes.
"A spectacularly fast car in a grand if dated tradition."
Old 10-11-2014, 09:26 PM
750hp's Avatar
That'll be fine Rob, as long as the ducting won't be getting heat radiating up from your side pipes.
Unless you're wearing double pluggers, you won't notice which direction the air's coming in. If heat is an issue, the main thing is to just get the air circulating down around your feet.
Craig
Old 10-11-2014, 10:45 PM
Wazza's Avatar
Really important to pay a lot of attention to insulating the footwell.....
dynamat,plus heat shield inside and out, plus a layer of underlay and carpet etc....and the temp on the footwell will never be a problem.
I've got all of the above,plus mirror stainless sheeting in the engine bay, that is spaced away from the firewall,with a good air gap...and my footwell gets neither hot or cold.
I recon it really pays off when you spend time on these sort of things....I've driven plenty of really nice looking Cobras,that just about melt your shoes..and are horrible to be in after about 15 minutes.
I just drove mine to the Nats and back,and could not feel the slightest heat...most of the time in bare feet.
Really worth the extra mucking about to get it right.
Warren
guye, mate and Gav like this.
Old 10-12-2014, 02:13 AM
sambo's Avatar
What did you use for heat shield in and out Wazza?
Old 10-12-2014, 02:59 AM
I have got 2 layers cross laid on all floor & walls of each foot well plus heatmat as under lay then carpet so its not going to be to hot but I was thinking of heat in just general driving , do I need vents in the foot wells [ as we have BIG foot wells & even just sitting not running they seem to get uncomfortable
OR AM I A BIG SOOK !!
ROB
Old 10-12-2014, 03:38 AM
Cobra Make, Engine: CR Cobra 3169
Try using black foam heat mat from Actroll Inns air conditioning. You can get most thicknesses. I have used it in a van to stop the heat from the back of the engine bay, as I had some cold storage in the back. I measure about 180 c on the engine side and only 30 c on the other.
JD
Old 10-12-2014, 07:10 AM
jcraigau's Avatar
Cobra Make, Engine: G-Force Mk1, LS1, T56, Jag S3 suspension
What about this stuff?
NanoBoost liquid applied automotive parts coating for thermal insulation
or Spray-On Insulation - Automotive Insulation Coatings | LizardSkin
Old 10-12-2014, 12:23 PM
cycleguy55's Avatar
I have heard some folks run exhaust fans in their foot wells to draw the hot air out, rather than attempting to blow cool air in. The challenge with blowing air in is the need to get fresh air from the front of the vehicle to the foot well without heating it along the way, while I think the theory behind exhaust fans is whatever air is pulled out will be replaced by fresh air pulled in through the cockpit. Certainly on my West Coast I can see how to route the exhaust air through the open channels under the doors and behind the rocker panels & side pipes, exiting into the rear wheel wells.
Thoughts?
Old 10-12-2014, 01:11 PM
Cobra Make, Engine: FFR
If you have good insulation, I don't think you need foot vents. The insulation is a huge factor.
Old 10-12-2014, 03:06 PM
400TT's Avatar
We provide driver and passenger footwell vents as a standard on PACE 427. We force feed the air from the radiator opening as per the original cars. We get plenty of air even at slow speed using this method.
From memory you are running yours off the brake ducts. We have never had much success doing that and use the brake ducts for what they are intended, force fresh air onto the brakes.
It won't matter where you position the air blowing into the footwell, it is all about circulating the air through the entire cockpit. Keep your hose bends to a minimum, use as large a hose diameter as possible, 2" at a minimum, preferably 3". And insulate the hose against the heat e.g. rising heat from exhaust etc. Also make sure you have some way to control the air flow, especially useful to be able to cut off airflow during winter.
www.absolutepace.com
Old 10-12-2014, 04:57 PM
Donunder's Avatar
While I agree with Craig that force-fed air through a large diameter hose is the ideal way to go, I have 2" diameter pipes running from the brake air inlets, with the inlets fully covered by a funnel so that all air is directed into the pipes.
Originally the footwells became very hot in the summer. The pipes duct sufficient air so that the footwells are neither cold in winter nor hot in summer. It's a nice neutral feel down there now, with the piped air gently displacing any built-up hot air, rather than providing a forced blast. The system could be more effective with larger pipes I suppose but for an inexpensive solution to having scorched feet during Queensland's summer months, I'm happy with what I have.
Don.
Old 10-12-2014, 05:39 PM
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
what do you guys do on colds nights or days to warm the area around your feet if anything at all
? cheers dean
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
Old 10-12-2014, 06:49 PM
Donunder's Avatar
For the four or five cold days we have in south-east Qld every year, we just grin and bear it!
Don.
Old 10-12-2014, 07:04 PM
sambo's Avatar
? cheers dean
A small heater box behind the dash with a vent into either footwell, does the job for me. Ski gloves come in handy during winter too.
Old 10-13-2014, 03:23 AM
well guys I have got mine off the brake duct ,, it has 2 openings top to foot wells bottom to brake s
craig.. yes thanks but I don't have a pace ,, so I have to run from the brake duct that has twin out lets
twin turbo.. I have 2 layers of insulation
don.. yep my ducting supplied by earl cobra is 71mm internal so this should flow & I got blower fans with the kit
so im thinking to put them as close to the front ducts to help force the air in
or am I on the wrong way & should be in the middle or at the foot boxes
all help is great ..thanks again rob
Old 10-13-2014, 03:32 AM
750hp's Avatar
I'm glad your parts finally arrived from overseas!
Craig
Old 10-13-2014, 12:50 PM
leroy17's Avatar
? cheers dean
Socks.
Wazza likes this.
Old 10-13-2014, 03:00 PM
400TT's Avatar
Well you did ask who else had them fitted.
If running from the brake ducts, you will need to use that supplied fan and also some way to block them off in winter.
For anyone else looking at doing this, really try to duct the air from in front of the radiator, it will force feed the air and blast it into the cabin.
Old 10-17-2014, 03:44 AM
just a quick up date
I fitted all vents as per my first posts with fans not connected & well nice cool tootes
wazza I like the thongs as well
I found that the 2 layers & heat insulation & carpet doesn't let any extra heat in but just normally heat so I opened the vent control & cool as a cucumber so now !!
big question is a fan control fitted to anyone'S car that's drivable SO IS THIS A WASTE or do I just run an on/off switch only
ROB
