Like Tree14Likes
Old 03-18-2015, 07:33 PM
Cobra Make, Engine: Robnell Blown LS1
A couple of other points to keep in mind..
Make sure your cats are placed not too far away from the heads to ensure they light off properly.
Also the MAF sensor needs to be around 400mm from memory away from the throttle body so the computer has a little time to adjust air/fuel ratios properly.
One last trick is to have a new carbon canister and don't hook it up until test day so that it's not soaked with fuel vapours..
Old 03-19-2015, 07:08 AM
albanycobra's Avatar
Late model cats also clean up the mixtures with secondary combustion hence cleaning up older motors with overlap cams. If mixtures are out then your Nox goes up and so on. So an older motor that runs well with new Commo or Falcon cats should pass.
Old 03-19-2015, 03:40 PM
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
if im using the cats and oxegen sensors and ecu that come off my donor engine a ve commy 6 litre one would think if those components are in good working order it should pass?i was going to use new oxegen sensors anyway as i get all my stuff at wholesale prices .i will try the cats and see what happens but if they need to be replaced then so be it .
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
Old 03-19-2015, 09:24 PM
Cobra Make, Engine: Dax
You should be fine with that setup, just make sure you put a fresh tank of fuel in it before you test, and that your charcoal canister is fitted up properly.
Beejay likes this.
Old 04-10-2015, 05:35 AM
Auswallaby's Avatar
Cobra Make, Engine: Pace 427 (#53) , LS3, TR6060
So has anyone bought an engine from Preston Motors Surplus Parts Warehouse in Melb?
Old 04-11-2015, 08:56 PM
Krait's Avatar
Bought my LS2 from Preston's back in 2008. No problem dealing with them. Dealt direct with Kevin Newell.
Auswallaby likes this.
Geoff
Old 04-12-2015, 02:03 AM
Philm's Avatar
I did have a small leak on the fuel tank so raw fuel vapor was being sucked into the machine.....took a few attempts to work that out.
I would also trailer the car there and the guy would be waiting so had no time to warm it up, I even went 1 hour earlier once and he was still waiting.
the last time I drove it there went for a cruise up the freeway for a few ks and then straight for the test. Passed no worries.
Phil
Old 04-12-2015, 04:10 AM
Zedn's Avatar
I havnt seen the test procedure, but i would have assumed the test would be at operating temperature?
Old 04-12-2015, 03:29 PM
Philm's Avatar
its a good thing to run it for a while to burn off any assembly lubes, sealants paint etc.
The test doesn't take long so to have it up to operating temp before they start is a good idea.
Old 04-12-2015, 06:49 PM
Zedn,
I think that your cats work better the hotter they are, so it is an advantage if you run the engine as hot as possible.
Ben
Old 04-22-2015, 05:18 PM
Cobra Make, Engine: Harrison build #98 with Supercharged 6.2L of Chev Power, TKO600 5 speed gearbox
I run a LS3 and went through the testing procedure before it was slightly changed in Vic to follow the other states.
Used OE cats and full exhaust system with mufflers exiting the rear of the car. When I did the test that they were happy with I can'r recall if I had the supercharger on there or not. Did 4 tests 1st one came close with full set up, then changed a few things and took the s/c off but it still didn't pass.
LS3 is a great engine, mine stock except for the little thing bolted on tht op and has 400+kW at the wheels. I'm sure you can use LS7 heads and get better and then start doing rods etc.... but the LS3 stock parts are pretty good.
Rate This Thread:
