Like Tree59Likes
  #61 (permalink)
Old 07-06-2015, 07:23 PM
Originally Posted by Towmaster View Post
Commodores all run the regulator in the fuel tank...... Mine is in the boot, only one -8AN line runs to the engine, good for 500+ rear wheel. It is, however, not in the wheel arch.
Yep, If you use the corvette filter regulator then most use the ford MPA in the tank. Much easier to fit and will accept the Walbro 255Ltr pump.
  #62 (permalink)
Old 07-06-2015, 07:27 PM
Cobra Make, Engine: 6.2L LS3
The fuel system setup was all done by Ian at this workshop
  #63 (permalink)
Old 07-06-2015, 07:40 PM
Double post sorry
  #64 (permalink)
Old 07-06-2015, 10:19 PM
Aussie Mike's Avatar
Neutral
I reckon a switch to a Jag rear would be a big step backwards in handling and performance.
No offence to any of our Jag rear equipped brethren
boxhead and Gav like this.
Mike Murphy
Melbourne Australia
  #65 (permalink)
Old 07-07-2015, 04:41 AM
Hmm how about a nissan r32 rear end like the harrison kits?
  #66 (permalink)
Old 07-07-2015, 05:06 AM
Modena's Avatar
e-clip, many others have been down your road, and they have SORTED IT. Don't try and re-invent the wheel, refer earlier posts.
boxhead and Jaydee like this.
Ben in AU
  #67 (permalink)
Old 07-07-2015, 06:54 AM
If you start cutting up the main chassis, your engineer wont like it. It will need to be torsion tested etc.
Take Aussie Mike's advice and cut down the rear suspension arms. Much easier.
JD
deano59 likes this.
  #68 (permalink)
Old 07-07-2015, 03:17 PM
gjkrv8's Avatar
e-clip - I'd focus on getting it registered as is. As Modena said - there are a few already well sorted CR's (also doing very well on the track too) that use the same rear end as yours - albeit with the bump-steer fix. I know because they have passed me :-)
Rego is hard enough without the whole engineering/testing of major chassis/rear-end changes.
Just my opinion though.
cheers
Gregg
mate, Gav, Donunder and 1 others like this.
  #69 (permalink)
Old 07-07-2015, 09:29 PM
Donunder's Avatar
I agree with the three previous posts.
No need to create more problems for yourself prior to rego.
There's probably a better way to say this, but put your rear end in Aussie Mike's hands and all will be well.
guye, mate, Wazza and 2 others like this.
Don.
  #70 (permalink)
Old 07-07-2015, 10:46 PM
Ewwww...
Mike Murphy
Melbourne Australia
  #71 (permalink)
Old 07-12-2015, 06:26 PM
boxhead's Avatar
Mando modded his rear top achieve more wheel dish.
This is mine with 15 inch and BillBoards (no modded suspension)
(sorry for yet another pic everyone)
Cruising in 5th
  #72 (permalink)
Old 07-12-2015, 06:31 PM
Thanks Dave. I was looking everywhere for a pic of yours with the billboards fitted.
I think Mando ended up with the same rear offsets as me.
Mike Murphy
Melbourne Australia
  #73 (permalink)
Old 07-12-2015, 06:35 PM
That's very interesting Mr boxhead. What wheel sizes are the 15" and offset ?
  #74 (permalink)
Old 07-12-2015, 09:01 PM
Gav's Avatar
Gav Gav is offline
Down in the weeds Dave
Aussie Mike, Donunder and DaveW like this.
Powered by Cu
  #75 (permalink)
Old 07-12-2015, 11:04 PM
boxhead's Avatar
Typical Gav, no grass anywhere on my block except were I do not want it.
750hp and Gav like this.
Cruising in 5th
  #76 (permalink)
Old 07-13-2015, 03:58 AM
750hp's Avatar
That photo of Box's car looks like proof that you can get the look you're after without having to reengineer your rear suspension. Good news!
albanycobra likes this.
Craig
  #77 (permalink)
Old 07-20-2015, 01:54 PM
Anyone interested in lending a hand in buliding the cobra, I need some guidance ?
  #78 (permalink)
Old 07-21-2015, 11:12 PM
boxhead's Avatar
I bought the rims second hand from an x member here. I will have them off in a few weeks, so will measure up, instead of guessing (and likely guessing wrong)
Cruising in 5th
  #79 (permalink)
Old 03-08-2016, 03:26 PM
Made a mock up of the pipe work needed for the radiator. Was thinking of getting it made up in stainless or alloy. Any advise would be appreciated.
  #80 (permalink)
Old 03-08-2016, 03:42 PM
Gav's Avatar
Gav Gav is offline
Buy a straight thermostat housing, that will simplify things a bit.
CSR Standard and 360 Degree Swivel Thermostat Housings | CSR
Powered by Cu
