Like Tree59Likes
  #81 (permalink)
Old 03-08-2016, 03:52 PM
boxhead's Avatar
Crap, totally forgot to get them off and measure.
Will try do so after Easter (pretty busy till then)
Cruising in 5th
  #82 (permalink)
Old 03-08-2016, 04:40 PM
Cobra Make, Engine: 6.2L LS3
Thanks Boxhead that would be great if you could those sizes.
Yeah Gav that will definitely make it easier
  #83 (permalink)
Old 03-08-2016, 04:41 PM
Tenrocca's Avatar
I used the flexible chrome\copper ribbed radiator hose, however the lengths are a little shorter due to using a different radiator and inlet outlet both being on the drivers side.
Cant see your header tank in there yet either? Mine is attached to the drivers side shock tower (see thread link below)
There are quite a few pics of different setups in the old LS engine bay thread:
The LS1 to LS7 Engine Bay idea thread
  #84 (permalink)
Old 03-08-2016, 05:03 PM
stephen low's Avatar
e-clip I had stainless tube fabricated for the coolant pipe runs to improve the look and help with maintaining the engine bay as pretty easy to keep clean.
Can't say that I've seen alloy variants in use and the risk of erosion is there too I assume over SS and alloy tarnishes pretty easily too.
Have a look through my "Slowy miracle build" thread, there will be engine bay photos of the above to give some ideas.
You need to plan quite strategically for an overall look and work towards that.
For example I'd probably go that nice black look hose option with silver fittings available these days over the braid as an alternate visual.
The trick is to get your end plan in mind now, a difficult task I know.
Good luck.
slowy
  #85 (permalink)
Old 03-08-2016, 06:30 PM
I may be a little anal, but I would get a new radiator made up with the outlets on the passenger side. I used alloy that was later chromed.
Ben
  #86 (permalink)
Old 03-08-2016, 08:16 PM
DaveW's Avatar
Hi e,
put a drain bung in the bottom of the lower pipe as well if there isn't one in the radiator already, makes it easy in the future.
An NPT or o-ring ORB fitting will do the trick.
Dave
albanycobra likes this.
  #87 (permalink)
Old 03-08-2016, 09:14 PM
Aussie Mike's Avatar
I'm with Ben on this. Get rid of the stock commodore radiator and get a double pass cross flow one built with the outlets on one side. It'll look way neater and save you a lot of heartache making the pipes.
Mike Murphy
Melbourne Australia
  #88 (permalink)
Old 05-27-2016, 04:54 AM
Hi Guys
Looks for some Front headlights and rear tail Lights found some rear Lucas branded ones on EbayUK but if possible would like to buy in Australia.
Does anyone know of a supplier in Australia that meet ADR ?
  #89 (permalink)
Old 05-27-2016, 06:18 AM
I got mine through Classic and Vintage Bulbs.
Anthony has been in business for a long time and had all the right parts. He supplied me Lucal L691 and L692 tail lights with the correct E-Markings.
For headlights you will need MGB trim rings and he has them too.
MikeFromPerth likes this.
Mike Murphy
Melbourne Australia
  #90 (permalink)
Old 05-27-2016, 09:39 AM
thankyou for this tip! Coincidentally this is exactly what i needed.
  #91 (permalink)
Old 05-27-2016, 03:48 PM
Modena's Avatar
I got mine from ebay before I found Anthony. I did buy headlights and all my LED bulbs from Anthony, so +1 there.
Ben in AU
  #92 (permalink)
Old 05-27-2016, 05:34 PM
Originally Posted by e-clip View Post
Hi Guys
I went to White Vision (AU company).. they have a 7" LED headlight that is ADR compliant.
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
  #93 (permalink)
Old 05-28-2016, 04:40 AM
Thanks Guys for the info
Anthony has emailed me back but is at the Winton historical show this weekend.
He said he has what I would need for the cobra.
Awesome thanks again for the info...
  #94 (permalink)
Old 06-03-2016, 09:18 PM
Default Land Rover LED lights
Hey Guys
What do you think about these in regards to ADR ?
E Marked and SAE Approved
Land Rover Defender 90 110 WIPAC Clear LED Lamp Upgrade Kit 73mm Lens - DA1191
  #95 (permalink)
Old 06-03-2016, 09:24 PM
Tenrocca's Avatar
Quiet a few have used the defender lights, although not in led. Not as nice and not as large as the l691/l692 lights IMO.
  #96 (permalink)
Old 06-03-2016, 09:49 PM
anyone know where to get them non-LED? the L692s might be a bit big for what i need (coz of the shape of the body in the taillight area).
shame the defender ones don't have a chrome surround.
  #97 (permalink)
Old 06-05-2016, 05:48 PM
boxhead's Avatar
10 Lights Lamps Landrover 90 110 Defender Indicators Stop Sidelight FOG Reverse | eBay
Cruising in 5th
  #98 (permalink)
Old 06-05-2016, 05:51 PM
boxhead's Avatar
With chrome.
Landrover Defender 110 90 Wipac LED Brake Tail Light Chrome RIM Trim Retro | eBay
Cruising in 5th
  #99 (permalink)
Old 09-14-2016, 04:52 AM
Default Fitted lights today
Starting to look like a car
boxhead likes this.
  #100 (permalink)
Old 09-14-2016, 04:59 AM
Is stone guard enough protection under the well wheels?
750hp and boxhead like this.
