3Likes
Post By Aussie Mike
Post By Gav
Post By Aussie Mike
11-04-2015, 10:29 PM
Vic
What is wrong with my clutch?
Something weird going on....after driving it for the first few weeks and starting to fang it at the nationals, I noticed that the fluid has gone "dark". It is the same Penrite race fluid as in the brake reservoirs, from the pic below you can see the difference. Fluid in the brakes has not changed at all.
I contacted Tilton and asked them for any possible causes, the only thing they could think of is that there was excess rubber grease in the cylinder from manufacturing assembly and it has tainted the fluid.
I drained the fluid, replaced, and bled out all the old stuff, and within 50kms of mostly freeway driving, it has happened again. If it is rubber grease in there then it must be a large amount !?!?!?!?!
The bite point has moved up the pedal too as this has happened - after ditching the first load of coloured fluid the bite point was very near the floor as I would expect with a brand new clutch and fresh fluid, now after the 50kms it is higher up slightly. Also when changing the fluid there was one air bubble in there which came out first.
Obviously I will change it again, but any thoughts?
Ben in AU
11-04-2015, 11:08 PM
Optical illusion? Swap lids.... Just a punt.
11-04-2015, 11:21 PM
Vic
hahah - very funny spook. The fluid came out plenty "dirty" when I changed it.
Ben in AU
11-04-2015, 11:34 PM
VIC
This is a common thing I've seen on LS engined cars. Commodores do it too.
I suspect it's to do with the design of the hydraulic throwout. Here's my theory:
Most cars with a clutch fork and slave cylinder have the slave on the outside of the bell housing. The cylinder bore of the slave is protected from the elements with a rubber boot over the pushrod.
The LS motor has a hydraulic throwout with a large ring shaped piston about 2" in diameter. There is no dust seal protecting it from the ingress of dirt and dust. There is also a lot of surface area on the sides of the piston and piston bore compared to a conventional slave cylinder. A lot more area for dust and dirt to collect. Each time that piston moves back and forth it tracks some of that dust and dirt back into the areas behind the piston seal. This discolors the fluid.
Mike Murphy
Melbourne Australia
11-05-2015, 12:06 AM
vic
I would put it down to your flamboyant driving style
Powered by Cu
11-05-2015, 01:13 AM
I did suggest I made a better grid girl!!!
11-05-2015, 01:17 AM
Vic
that sounds logical enough Aussie, but I wouldn't think this would happen after a mere 50kms where 40km of it was freeway ?!?!?
Ben in AU
Mike would that show evidence after only a short distance like that which Modena suggested? I'm curious now.....
11-05-2015, 01:20 AM
Vic
I thought first that it is heat related. The cat is right under the cylinders although about 40cm below, and it gets mighty hot in there. The clutch line also passes somewhat near the headers but not really that close.
I plan to put another heat shield over the cat to keep the heat away. The clutch line is braided stainless.
Ben in AU
11-05-2015, 01:26 AM
Vic
Ben in AU
11-05-2015, 01:43 AM
NSW
Something to do with the Dark-side ?
11-05-2015, 02:16 AM
VIC
The rubber grease in the slave cylinder they mention in that thread could be believable too.
I know mine had gone dark when I checked it after only a few miles.
It doesn't seem to affect it's performance.
Mike Murphy
Melbourne Australia
11-05-2015, 02:49 AM
NSW
Following Mike's first suggestion. I wonder if it takes some time for dust to accumulate in the bellhousing from an initial 'clean' build. Fluid from re-bleed is however quickly contaminated by the existing dust deposits in the bellhousing?
Can you flush out the bell housing next time you replace the fluid and see then how quickly it darkens.
11-05-2015, 11:26 AM
Member of the north
Cobra Make, Engine: A Cobra
Mine did the same thing followed by a Master Cylinder failure.
Masters are over my headers and the heat boiled out the fluid to the point oxidation took place. I was getting the rust from the failing cylinder.
Put in heat shield and replaced the unit.
Not sure if this is the same as yours.
Tru
11-05-2015, 03:08 PM
VIC
I'm reluctant to think it's heat related in our cases. All 3 master cylinders are above the headers with no discoloration in the other two. The brake lines run down the foot box and past the headers too.
Mike Murphy
Melbourne Australia
11-05-2015, 03:11 PM
sa
could it not be discolouration from the rubber lines going from the master to the slave cylinder ? just a though
11-05-2015, 03:39 PM
VIC
I run a braided Teflon line from the MC to the Clutch. I think Ben does too.
Mike Murphy
Melbourne Australia
11-05-2015, 03:46 PM
vic
I don't have a clutch but my master cylinders are directly above the headers and the fluid doesn't discolor. It's not heat.
Powered by Cu
11-05-2015, 03:52 PM
NT
Personally I think you are worrying over nothing.
Next you will be chasing answers as to why the engine oil goes black so fast.
I have done 12000kls now and not changed the fluid, it is darker than the brake fluid (But I used a dark green colored fluid), it still operates perfectly well.
Cruising in 5th
11-05-2015, 04:06 PM
If the " Bite point" has changed this may indicate that MC piston is dragging on one side of MC bore. If pushrod from pedal is poorly aligned this will happen quite readily, followed by failure of the seal. Result is like scrubbing that old aluminium pot in the sink........goes black pretty quick.
