Like Tree12Likes
  • 1 Post By Auswallaby
  • 2 Post By Tenrocca
  • 1 Post By Cobrakiller
  • 1 Post By Mrs flatchat
  • 5 Post By Aussie Mike
Old 12-30-2016, 06:23 PM
Auswallaby's Avatar
Cobra Make, Engine: Pace 427 (#53) , LS3, TR6060
Default TR6060 to LS3
Ready to install my eng/gb. My crate ls3 came with the clutch installed and the tr6060 has the bell housing and htob installed already. The distance from the edge of the bell housing to the front of the htob is 82mm, but if I push back on the htob it goes back another 28mm under a spring tension. The distance from the back of the block to the clutch fingers is 108mm, so if I mate the trans to engine as it is, the htob will be pushed back 26mm under spring pressure and still have 2mm before it hits the front of the gb. So is it normal to have the htob touching the clutch fingers under spring pressure?
Additional question, do you still need to centre the bell housing with modern setups?
albanycobra likes this.
Old 12-30-2016, 06:49 PM
Auswallaby's Avatar
OMG I GOT THE PHOTOS TO WORK!!!!!!!!!!!!!!!
Forget dropbox, go with photobucket!!!!!!!!!!!!!
Old 12-30-2016, 09:15 PM
Tenrocca's Avatar
Yes the throw out bearing is in constant contact with the fingers.
Check this out for checking your measurements:
Does YOUR Clutch Setup need a Shim? - LS1TECH
joyridin' and Auswallaby like this.
Old 12-31-2016, 02:07 AM
Cobrakiller's Avatar
Sounds alright, the series 1 VE TR6060 does not fit the dual mass clutch set up in the current LS3 engines from Holden without changing the slave cylinder and some minor mods to the pilot bush (ask me how I know ) . Looks like you have the series 2 VE TR6060. Difference is the input shaft has the spline machined off the first 30mm or so like yours but the series 1 VE TR6060 has the spline the full length of the input shaft. You do not need to clock the bell housing to the input shaft
Auswallaby likes this.
Old 12-31-2016, 04:42 PM
Mrs flatchat's Avatar
Wink
From the block to the clutch fingers is 108 --yeah ?
from the bell face to TOB is 82 + 28 = 110 -yeah?
that leaves 2 -- not enough
**The TOB should have about 17 crush when assembled**
ie the 108 will increase to ~112 as the clutch wears
The 82 should be 90
or the 108 should be 100
hope that helps
SydneyChris likes this.
Old 01-02-2017, 02:50 PM
I have the same set up.. pre load (or crush) is critical to get right. From memory the preload range was 17-21 mm. If you are having ongoing issues contact Mal Wood Automotive.. they have a custom slave cylinder and a range of shims available.
For my frustrated ramblings at the time see ... Hydraulic clutch set up
Good luck..
Chris
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
Old 01-04-2017, 01:05 AM
Aussie Mike's Avatar
I've machined a bunch of T56 gearbox front plates to increase throwout free space. I machined up a special collett to locate the front plate on the input shaft bearing.
deano59, albanycobra, Gav and 2 others like this.
Mike Murphy
Melbourne Australia
Old 01-05-2017, 03:46 AM
Slave cylinder part # for the the VE series 2 - VF is GM 92251476 This suits the TR6060 with the dual mass clutch setup as in the posts above.
VE series 1 slave cylinder part # is GM 92227219 this is approx. 40mm longer than the series 2 setup and is for the single plate non dual mass setup LS7 clutch etc. There is very little info around on these differences, might help someone else with there TR6060 dilemas. I used the factory clutch pedal and master cylinder. Note the spline is the full length on input shaft in this pic of a series 1 TR6060.
