Like Tree2Likes
Old 01-14-2017, 01:50 PM
Gav's Avatar
Gav Gav is offline
I'm fitting an electric power steer pump on the coupe.
It's just a simpler way to go I think.
Powered by Cu
Old 01-14-2017, 03:48 PM
Cobra Make, Engine: Robnell Blown LS1
I'm using an MR2 spyder unit (2000 plus model) on my Cobra.
Has been on it for about 4years now and have had no problems other than shorting out the first one when trying to use spade connectors instead of factory plugs
Expensive lesson!!
No sign of cavitation with quick steering movements.
I found a short video of the setup, but the guy states in the video "you always get full pressure with no VSS hookup" which is incorrect.
I don't have VSS hooked up and it provides full assistance when using larger steering movements, then when not loaded the pump automatically drops pressure until it senses the need again.
https://youtu.be/CNq93zZEJMU
albanycobra likes this.
Old 01-14-2017, 07:42 PM
Cobra Make, Engine: rmc 302
my car doesnt matter what angle you put the electric power steering.
Old 01-20-2017, 01:34 AM
Originally Posted by Hail427 View Post
I just googled electric assist steering column, as albanycobra mentioned and;
https://www.youtube.com/watch?v=uKzCaEjvJeM
I haven't looked into it further I'm not going that way but I hope this helps to further your search
The angles on that american installation are terrifying. 15 degrees is the preferred angle.
Old 01-25-2017, 01:29 PM
Laurie Bongalis in Blackburn Melbourne (RCM Cobras) has an electric power steering conversion using an adapted Honda rack.
Old 01-01-2022, 05:33 PM
Cobra Make, Engine: Midstates, 428SCJ
I had previous searches for my cobra. I have a 66 Jag manual rack and pinion (great handling when moving extremely difficult when parking) There is a You Tube where a gentleman compares multiple units. His recommendation is for a unit from a Toyota Corola 2003-2007 I believe. Reason being it can be used wiring only 3 wires and do not need ECU, but mainly if you loose power it does not lockup but returns to manual control.
Old 01-02-2022, 05:37 AM
Tom Wells's Avatar
Ken did the conversion some years ago. He describes it in detail here: https://www.firstcoastcobraclub.com/...hilit=steering
As far as I know he has used it satisfactorily on the street and at Daytona track days.
Enjoy,
Tom
