Old 08-25-2017, 02:55 AM
Cobra Make, Engine: Python
Default High CCA Battery Options
Gday people
Can you good folk recommend a good battery for a highish compression motor.
Running 11;1, 331 Windsor and although it has just been started , the regular heavy duty battery is dying quickly cranking it. Looking for something better.
Chris L
Old 08-25-2017, 05:16 AM
Gav's Avatar
Gav Gav is offline
I used an optima in the Cobra.
It is now in the 911 and still going strong.
Powered by Cu
Old 08-25-2017, 02:34 PM
stephen low's Avatar
Chris
Am running an Odyssey PC925, 330 CCA which is fine for the 5L Windsor and quite a small sized battery for its punch.
These are a sealed and can be mounted in any configuration except inverted, so on their sides if needed for space reasons.
They do a large range of other models with even higher cold cranking and pulse crank ratings as per the link below.
Extreme Series Battery Specifications
slowy
