Old 09-28-2018, 07:52 PM
Cobra Make, Engine: 6.2L LS3
Default Classic Revival square tube body removal ?
Hi Guys
Just wanted to remove the body from my Classic revival square tube Chassis (came fitted) Can anyone explain what the best way is to go about it ?
And the best way to store the body once off any weak points ? is on a flat surface fine or on saw horses ?
Thanks
Michael
Old 09-29-2018, 06:49 AM
Gav's Avatar
Gav Gav is offline
Undo to the bolts and lift it off!
Nose up and lift it towards the back.
It should sit on a flat floor with no issues.
Powered by Cu
Old 09-30-2018, 07:12 PM
Tenrocca's Avatar
I think you have to lift the rear and slide it forward Gav. I know you tried to remove it sliding it backwards in the winton carpark.
Old 10-01-2018, 06:04 PM
Gav's Avatar
Gav Gav is offline
Double up
Powered by Cu
Old 10-01-2018, 06:06 PM
Gav's Avatar
Gav Gav is offline
You are right on one point there Dave 😉
I forgot to undo the bolts at Winton...
The back does come up and it goes forward because of the bar between the two front openings.
Powered by Cu
Rate This Thread:
