Old 07-06-2003, 02:47 AM
347's Avatar
347 347 is offline
Cobra Make, Engine: .
Default 4 barrel
would a four barrel give me much more hp than webers?
Old 07-06-2003, 07:10 AM
Ron61's Avatar
Post
I don't think it would give you as much power as well tuned Webbers but if you drive your car on the street a lot you would probably have a lot less tuning to do. Also possibly better gas mileage. My knowledge of Webbers is from the late 50s and I know they have made huge improvements in them since then but back then they gave more power than a four barrell.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 07-06-2003, 07:23 AM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
No. Eight properly sized venturi will always be better than four. The same can be said for 8v carburation.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 07-06-2003, 07:50 AM
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
Depends on what do you mean by "power". If it's high end power the answer is a four barrel hands down, assuming that you don't have to go around corners fast. If it's about the street or in some cases road racing the nod goes to the IDA's cool looks. Forget about the webbers tuning problems. Once they are set up they will generally stay put, unless you change your engine setup. And there in lies the problems with webbers. It's hard to leave these hot rods alone now isn't it? Guys change engine setups like I change my socks. BTW- in case you haven't noticed, a good webber setup costs a wee bit more to.
cobrashock
Ron Shockley
Rate This Thread:
