Old 10-10-2003, 06:27 AM
347's Avatar
347 347 is offline
Cobra Make, Engine: .
Default oil
What oil do you guys use?
Old 10-10-2003, 06:35 AM
I used to use Brylcream..but since the hair started falling out.....I dont use any now.
For what it's worth.....after a thorough run in on any high quality mineral oil....I then like synthetics
Old 10-10-2003, 07:44 AM
BPWilliams's Avatar
Cobra Make, Engine: none
Smile Oil
Mobil 1 15-50 syn. I have heard that you want to keep your viscosity low so the oil gets into small places??? but I do not follow that line of thinking. after a couple of laps at the track the oil is nice and hot and it should flow like melted butter. Now if you are going to just drive on the street. I would tame it down to 10-30, or 15-40 tops.................
Keep the shinny side up..................
Brian
There is No Replacement for Displacement.
U.S.A. All the Way!
Old 10-10-2003, 08:42 AM
rdorman's Avatar
Renegade Nuns on Wheels
Mobil 1. Is there any thing else? I run 5-30 year round but depending on how 'tight' your motor was built you vary the weight to get the pressure where it needs to be.
OhioCobraClub.com
LondonCobraShow.com
Old 10-10-2003, 09:11 AM
Rick Bagley's Avatar
Cobra Make, Engine: Unique 427 S/C, Red w/White Sripes, 427 SO, 4 speed Top Loader
Redline 20-50 in a "loose" 427 Side Oiler. Have been using it for many years in other cars and motorcycles. You can't get it at WALMART.
Eliminator
Old 10-10-2003, 09:32 AM
rdorman's Avatar
So there is something else! RedLine makes an excelent product. Has for many, many years.
OhioCobraClub.com
LondonCobraShow.com
Old 10-10-2003, 09:36 AM
BPWilliams's Avatar
Thumbs up ALSO................
Yes Red Line is also a great product!
Brian
U.S.A. All the Way!
Old 10-10-2003, 09:37 AM
REDSC400's Avatar
Send a message via AIM to REDSC400
Redline 20-50 or Amalie 20-50 Hi Perf.
Art in CT
Old 10-10-2003, 09:53 AM
Mr.Fixit's Avatar
valvolene 30 non-detergent for engine break in
valvolene 20-50 during warm months
synthetics if you have the $$$
Old 10-10-2003, 11:14 AM
HIQ's Avatar
HIQ HIQ is offline
I run Mobile 1 in all my cars. My Audi runs 10 degrees cooler with the Mobile 1 during the warm months so I figure it is worth the $$.
'It's not getting any smarter out there. You have to come to terms with stupidity and make it work for you.' -- Frank Zappa
Old 10-10-2003, 06:09 PM
750hp's Avatar
Castrol Formula R for me (20/50) . I like the idea of synthetic, but engine builders recommend against using it with solid roller lifters. Too little friction keeps the roller lifters from "rolling" - they just slide over the camshaft lobes. Not good...
I've had my oil to 265 degrees F and it maintained perfect oil pressure.
Craig
Old 10-10-2003, 08:13 PM
Bob In Ct's Avatar
I use Mobil1 5W-30 year round in my 351W crate. Good pressure all through the RPM range. Idles at 40ish, 55 PSI at 2000. Avoid the Fram filters. Using higher viscosities may lower your pressure!
Old 10-13-2003, 05:53 AM
PCC's Avatar
PCC PCC is offline
DULUX All in One.
Leaves a nice shine on the engine!
Seriously, Castrol GTX2 - Reasonably priced and has always preformed well in England and here in Australia
PCC (Peter Craig)
Keep the sun shining
