10-13-2003, 06:03 PM
Oh
Cobra Make, Engine: Unique 289FIA / SA 351W / a truly glorious machine
Sheared bolt on Jag rearend
I'm going to expose my mechanical inability with this question.
Just got out from under the Unique 289 and doing a little cleaning I found a sheared bolt (one of two) holding the left rear suspension to the differential. The bolt head is flopping around and still wired to the bolt to the rear of it... the other three bolts seem intact.
Any input would be appreciated....
10-13-2003, 07:32 PM
Qld
Cobra Make, Engine: Now built a race cobra.
jag rears.
HI i would recomend you buy 4 new bolts from a jag dealer as they are a special bolt with a taper on them and make sure you torque them up to the recomended spec . make sure you put oil or anti seize lube on the thread and then lock wire them.
regards oz
10-13-2003, 08:09 PM
Casaleenie,
are you talking about the Double ended bolt that carries the lower control arm? does this also mount your diff. to the frame in a unique?
KK
10-14-2003, 12:05 AM
Casaleenie, As oz says..get new bolts..very special ones they are, and take note of the proper way to wire the bolts.
However, I would also recommend you bolt a plate under the diff. If you look underneath that bracket, you'll notice two machined bosses with two threaded bolt holes in each boss. One boss at each end of each bracket.
On a jag there is a plate bolted under the diff which ties both those brackets together. Tis good insurance.
JUst dont forget to drill a large hole under your oil drain plug.
10-14-2003, 07:24 AM
Vic
I've had the same problem myself (a couple of times).
When I went to the Jag joint to get some replacement bolts, the guy said this was a common problem, especially when you don't wire them in.
Make sure you get that plate for the bottom of your diff.
Good ol'Rebel. 270 posts of rubbish and he's finally come up with a winner.
I'd say he could retire from the forum now, but we already out number the QLD's 10 to 1
so he better stick around.
10-14-2003, 07:32 AM
Renegade Nuns on Wheels
Oh
bottom plate
Any one have a good source for the plate or tips on how and out of what they have made theirs?
10-14-2003, 07:43 AM
Vic
I screwed a couple of bolts in to the base.
Pressed a piece of cardboard on to it.
Used that as a template to put the holes in to a piece of 4mm steel plate.
10-14-2003, 07:48 AM
ESP
check my photo gallery, you will see how the bottom plate for the diff looks like. I recomed it and think it is absolutely necessary if you really abuse the car.
Stefan
10-14-2003, 08:47 AM
Oh
Sounds simple enough.
By the way stefan, very nice.
10-14-2003, 10:20 AM
Oh
Reptyl,
They were and still are wired.. The only reason the bolt head is still there is because of the safety wire...
On the CWI website for Jag parts the screw ID numbers are
#1177 and #1209.. Someone posted on the Unique forum that the bolts are different lengths...
My mechanical abilities amount to using my finger to dial a garage.
KK,
No, I'm referring to the bolts that enter the differential casting and hold the bracket that the lower control arm pivots on.
Rebel,
Sounds like the thing to do. I'll check into it...
Stefan,
Don't really abuse the car but thanks for the input... Sounds like good insurance....
Reptyl,
When you say "the jag joint" are you referring to the Jag Dealer parts dept.. ??
And thanks a million guys,,
10-14-2003, 10:27 AM
Oh
How do I print the thread on the bolt without printing all the colors and extra stuff???
10-14-2003, 10:31 AM
Vic
The Jag joint was a Jag wrecking yard here in Australia.
Even if the bolts weren't wired the head can't fall out because the LC/Arm needs to be removed before the bolts can come out.
They are different lengths, about a 1/4 inch difference from memory.
10-14-2003, 03:33 PM
Jason ..my olde mate ...wot you pickin on me for hey?..I been a good lil fella and not even picked on ya for at least...ermm..maybe a week.
You better watchit fella cuz if they ever let me into Victoria ever again then your gonna end up with a headache.
Wouldn't be the first time I've had to drink some southern cousin under the table
10-14-2003, 04:30 PM
IN
Cobra Make, Engine: Contemporary-Aluminum 484 FE
Hi Guys
Just when you thought that you had got rid over me to the States I turn up again.
As you can guess I am with Wayne Turpin in Evansville Indiana.
So its Bernie Knight "Posting" under wtcobra.
Hope this is legal
As Wayne is an Attorney I will pass it by him.
Arrived in LA last week and then spent a few days in LA checked out all the beaches and the U.S babes on the beaches. Actually it was cold.
Had a visit to the Petersen Museum and then across to Chicago and down to Indy. Went to the Indy museum and did a track tour. Down to Bowling Green Kentucky and a visit to the Corvette Museum and the Plant tour.
Off to Gateway Raceway in St. Louis Missouri tomorrow for the Run N Gun. Meeting Robert Logan from Roarin Forties there.
Well I am having fun and will be back in early November.
Cheers all
Bernie Knight
C/O Evansville Indiana (wtcobra)
[img]http://www.clubcobra.com/photopost/uploads/9771/WayneTurpin.jpg[img/]
10-14-2003, 05:19 PM
Bernie ... Just make sure you DO behave yourself and dont disgrace us Aussies left workin our butts off back here.
For what is's worth..I'm told the Ladies in the States just cant resist the Aussie lingo. They (the US ladies) claim the American fellas just smile at em and keep going....Us Aussies engage in conversation they find appealing. Maybe that's a sign of desperation
For all our American cousins...excuse Bernie for any sins he may engage in whist over there...he isn't representative of NORMAL Aussie fellas
