Old 01-14-2004, 03:25 AM
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
Default Pedal Boxes and Emissions
Ok.
Back AGAIN!
A simple one to start with... Does the RMC kit start with the pedal box assembled? Those with a Holden RMC kit, what did you require from the donor? I'm hoping to keep the 3.08 ratio in the diff cause I do some highway k's and hate to over rev! But what else? Does the diff just need a freshen up? Or does it need shortening?
Those with the Jag version, any of ya's have the Ford rear end? I might be able to get a IRS rear end easy enough.... What work is envolved? Anyone here heard/done one?
AND...
According to the way I read the current regs LPG is possible. A CAT conv. has to be ran as per the standard emissions laws, otherwise seems ok.??.?.? Can I get an old 351, gas it, fit a CAT with the nessesary engine stuff like no smoke, hardened seats, and pass? Anyone have any idea?? Before I ask the engineer? What hoops are the cars tested on before rego? I assume a gas gun is run up the back and a sound test done??
Nathan
Old 01-15-2004, 04:16 AM
REPTYL's Avatar
Re: your gas question.
I only just snuck through in 1999 with my gassed Clevo before the regs got changed in Victoria in regards to the age of a motor.
Contact Vic road for a copy of the Current ADRs (Australian Design Rules)
Old 01-15-2004, 04:31 AM
sevenohms.. aren't you referring to the BRB kit?. It comes either GM (torana) or Jag rear end for the 2000 series.
Far as I know, the RMC only comes as a jag rear kit.
