Old 01-15-2004, 02:13 AM
BJ's Snake's Avatar
Default cylinder numbering
OK Guys,
To settle a friendly arguement,can any one tell me the cylinder numbering and firing order for a 5litre HO mustang motor.
cheers
BJ
Old 01-15-2004, 02:22 AM
750hp's Avatar
The 5.0 HO motors use the 351W firing order of 1-3-7-2-6-5-4-8
cylinders 1-4 are the driver's side
cylinders 5-8 are the passenger side (in Australia !)
cylinders 1 and 5 are at the front of the motor, and work their way back.
Craig
Old 01-15-2004, 03:39 AM
What Craig said
Old 01-15-2004, 06:07 AM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Just to clarify what Craig said, cylinders 1-4 are on the driver's side in Australia, which is the RIGHT SIDE in any country. So, 1-4 RIGHT SIDE; 5-8 LEFT SIDE looking from the rear face of block forward.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 01-15-2004, 09:32 PM
BJ's Snake's Avatar
Thanks guys,
I win.
BJ
289 FIA Cobras RULE!
Old 01-15-2004, 09:53 PM
Aussie Mike's Avatar
I think My Ford 351 Cleveland is the same.
Silly system, it should be
.........1
2........
.........3
4........
.........5
6........
.........7
8........
Mike Murphy
Melbourne Australia
Old 01-16-2004, 02:16 AM
boxhead's Avatar
Cylinder #1 is always the forward most cylinder (easy to see with no head)
Because the 2 forward most pistons (and every opposing cylinder from there back) use the same journal, the easiest way to see which bank is #1 is to see which piston is the most forward.
Cruising in 5th
Rate This Thread:
