Old 02-04-2004, 03:18 AM
Cobra Make, Engine: Antique & Collectible 351 windsor bored and stroked tko tremec
Default tilton floor mount pedals
i all i have presently installled my tilton racing floor mount pedals they are wonderful. but now i need to find a way to install a brake light switch. i have checked with tilton wildwood jegs summit and a few others for an inline brake pressure switch. and they say its not avaliable. so i dont know if there is another way to mount a regular elect switch, and possibly make a bracket. well any info would be greatly appreciated. thanks Neil
Old 02-04-2004, 03:27 AM
750hp's Avatar
Neil - the guy that built my car over here (you posted this in the Australian section ) simply used an electrical switch off some non-descript import car, and made a small mount off the pedal box mount. They're small switches, so it shouldn't look ugly behind your brake switch.
Old 02-04-2004, 05:52 AM
Neil, like you I use the Tilton Floor mount system and use an electrical presure swith mounted inline with the rear brakes which is mounted directly on top of the the main rail behind the motor mount pillar. It works fine and I've never had a problem with the set-up. If you need pictures I'll try to get some for you - if not best of luck!
Old 02-04-2004, 06:27 AM
Where did you get it from? we can't seem to locate any such thing! any part # would be great. Thanx Neil
Old 02-04-2004, 06:50 AM
Neil, give me a call at the office at 800-895-7531 x101 when you have a chance.
Old 02-04-2004, 07:09 AM
Neil,
The instruction manual says to use the Stop Light Switch Ideal #SLS33. If that is what I have I can't tell you but it is what the assembly manual says to use so it most likely is correct. Best wishes!
