Old 06-25-2004, 01:48 AM
347's Avatar
347 347 is offline
Cobra Make, Engine: .
Default efi
I am dumping my webers and coverting to efi.
You guys running 347's, what manifold,size throttle body,size injectors,ecu,heads,cam are you running?What sort of power are you making?
I am planning to run a trickflow R manifold,75mm throttle body,32lb injectors and a haltec E6X ecu(on a 347 ported windsor snr's solid flat cam 248@.050, .560 lift, 110 lobes,10.1 comp....any opinions on this set up? Good bad or other wise?
