November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-21-2004, 05:06 PM
Cobra Make, Engine: RMC Cobra, 5.0ltr HO 4 Speed Top Loader
Question Side Pipes
I'm first time on so bear with me. I've recently purchased RMC model with 5.0ltr 4 speed. Now i want to bring it up to my expectations. Already transfered rego from WA to Vic with Personalised Plates REPTLE.
I'm looking for side pipes wether to make myself or purchase?
Where to buy or find kits please advise.
Looking forward to hearing from anyone.
And yes i am a member of the Vic Club.
Regards Paul
REPTLE
Paul Delnegro
Reptle
Old 07-21-2004, 05:29 PM
PCC's Avatar
PCC PCC is offline
Hi Paul,
Welcome aboard this merrygoround full of advice, experience, information, and b$%%@$*t
Regards the sidepipes, I'm sure the fabricator boys will chirp in, but to get you going do a search on sidepipes as there is plenty of threads that will provide the info you're looking for.
PCC (Peter Craig)
Keep the sun shining
Old 07-21-2004, 08:53 PM
Cobra Make, Engine: 302 windsor, trickflow heads, gt 40 intake, 65 mm throttle body, autronic computer, custom headers, glimer drive , toploader
Talking nice one
I personally know that your number plate will at least annoy someone
king jason the 2nd
Old 07-21-2004, 09:00 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
I have built side pipes for a few cars in the past as well as our newest demo with the 4.6. It is no easy task and can take days to make up that first set of headers & side pipes. Unless you have a true bender like a Ben Pearson and a few years of making exhaust pipes at a muffler shop it is in my opinion not worth all the work. Figure 2 or 3 days at 50hr x 16 or 24 hours plus material wasted on pipes that don't fit, then having to clean the pipes and paint them, coat them or pay to have them chromed and you can get an idea why.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 07-21-2004, 09:39 PM
Tony Cram's Avatar
Cobra Make, Engine: 1991 RMC 1966 427SC replica, 302 Cleveland, Edelbrock manifold with 600 Holley double pumper.
Paul,
I think pretty much all the manufacturers of cobra kits also sell working and fake side pipes. Talk to Kim at RMC WA (Check my photos - mine are RMC working sides with cats), Rob at G Force WA, Don Pilling Snakebite in Qld, DRB sportscars Qld. There are some others and I am sure you could get them locally here in melbourne, I'm sure someone knows somebody. All on the web except RMC and Snakebite you need to phone these guys.
Good luck!
Regards
Tony
Old 07-21-2004, 09:53 PM
Aussie Mike's Avatar
I've been getting quite a few enquiries from people about my side pipes and whether I could build a few sets.
I can supply side pipes from the 4 hole flange just inside the guard. they would come with a coresponding 4 hole flange plate that you can build your headers to.
the rear mount can be supplied but not welded onto the pipe as different chassis will have different pick up points.
My pipes have Hi Flow Catalytic converters inside them and the baffles and Cats can be easily serviced or replaced. They have 2" primaries and 3.5" merge style collectors. The muffler body is 4.5" and splits apart from the collector to let you get at the baffles and cats. The tip is also 3.5"
I can also make them in different lengths to suit streched wheel base cars.
I'm looking at Au$1600 a pair uncoated in steel.
The materials are fairly expensive ie the cats are $250 each. The mandrel bends in different radius to tuck in close to each other are a special order and are between $30-$50 each. the flanges for the muffler body are machined from 5" bright steel billett.
There are a few pictures in my gallery to give you some ideas of what they look like and if you are in Melbourne you're welcome to come and have a look.
Here's a few pics:
Side pipes 1
Collector
Side pipes2
Mike Murphy
Melbourne Australia
Old 07-21-2004, 11:16 PM
Cobra Make, Engine: RCM, 4 wheels, two doors
Mike,
What would your price be for non functional side pipes? $500 less (no cats)?
I haven't looked into side pipes in any detail yet.
Any guess on $$ to chrome them?
After seeing your pipes in person, the pics don't do your work justice
Old 07-21-2004, 11:36 PM
There's not just the price of the cats to knock off there's also the labour and materials for the baffles and flanges.
I figure they would end up being about $700-800 the pair, maybe less.
I'm not a big fan of chrome on this type of structure. When they electro plate something they put an electical charge through it and dip it into a tank of electrolyte solution. The charge flowing between the part and an anode of chromium pulls molecules of chromium from the from the anode and adheres them to the surface of the part. This works great on simple shapes but when you get angles and crevices the oposing fields in the sides of the valley don't allow the chromium to get to the root of the valley or crevice. This means you will end up with little or no chrome in the gaps between the header pipes leading to rust down the track.
There are some good plating shops out there that can do a good plating job on this type of stuff but I still worry about the longevity of it.
I think the best bet is polished stainless steel for a shiny chrome finish on this kind of part. I think I could do some cosmetic stainless pipes but I'd have to have a bit of an experement with how to do it.
Mike Murphy
Melbourne Australia
Old 07-22-2004, 12:44 AM
justbetter's Avatar
Cobra Make, Engine: Superformance AUS002, Chev 5.7 with hairdryer
Red face Not yet though
Not yet though Mr Mikey, you just get and finish yours.
by the way and the GST component was located where !?!
Garrett
COBTHS
Superformance SPF AUS002 "Modified"
Old 07-22-2004, 01:17 AM
That'll be the Get Stuffed Tax would it?
My wife has an ABN number. I think making Cobra bit's might be an interesting side line for her.
Mike Murphy
Melbourne Australia
Old 07-22-2004, 01:22 AM
Thanks Mike,
We'll talk AFTER the Nats
I wouldn't want to be the poor red herring blamed for you not getting to the Nats this year
BTW, if ya need help with the ol' GST let me know
Old 07-22-2004, 03:08 AM
boxhead's Avatar
Hey there Mike, after we here your pipes and if they are under the required Db level then I will get a set from you either late this year or early next (not till after nationals)
Sounds like a very good price to me, especially after seeing them.
Cruising in 5th
Old 07-22-2004, 06:07 AM
BMK's Avatar
BMK BMK is offline
Aussie Mike Pty Ltd Exhaust Manufacturer.
Didn't take long
Now there's a way to get the wife working. Spouse is a manufacturer of exhaust systems?
I'm sure the A.T.O will believe that one
Seriously I think its a great idea Mike, you have all the equipment and obviously the ability so go for it. Well done. Your pipes look great and are well made.
Bernie
Bernie Knight
