07-31-2004, 06:23 AM
vic
Cobra Make, Engine: DRB2000 Ford XR8 5lt HO roller rockers Jag running gear
oil filters
Hi all,
I just put the engine in again and went to fit oil filter !!!!! don't fit, to big ,tried a smaller one still to big, so can anyone help. I need a filter to fit the 5lt 3/4bsp thread I think but needs to be no longer than 70mm the ones I have tried are z9, z170 I hope someone can help or I will have to cutup the chassis again to find room.
Chris
07-31-2004, 07:01 AM
Chris:
Use a remote filter setup.
07-31-2004, 02:45 PM
NM
Cobra Make, Engine: Cardiac, 428 FE
Remote oil filter
Go to Amsoil.com
Here's the link to bypass filter installation with photos.
http://www.amsoil.com/products/bf.html
You can get a bypass filter combined with a full-flow filter and the hardware to install it from them.
There are lots of opinions about what oil to use, so I won't go into that but the Amsoil filters are high quality, as is the remote setup they sell.
Paul
08-01-2004, 02:05 AM
VIC
Cobra Make, Engine: RCM, 302 Windsor EFI
Hi Chris
Ryco make a filter Z89A which might fit.I think the remote is the way to go.
08-01-2004, 03:44 AM
vic
Thanks guys,
I had thought about a remote filter but was hoping for a easy fix but doesn't look like there is one so I will have set up a remote, more time!!!!!
Chris.
08-01-2004, 08:35 PM
vic
Cobra Make, Engine: 302 windsor, trickflow heads, gt 40 intake, 65 mm throttle body, autronic computer, custom headers, glimer drive , toploader
ah the joys
king jason the 2nd
08-02-2004, 03:47 AM
Hey Chris....Wait till pete (PCC) answers ya...he's got one of them DRB 2000 thingys.
He'll give ya an idea wots on his.
08-02-2004, 04:43 AM
Z9 and it fits with room to spare.
My engine is an NC Fairlane so may be different to your's Chris
Sorry
PCC (Peter Craig)
Keep the sun shining
08-02-2004, 05:40 AM
vic
Thanks again,
Pete my engine is out of a xr8 but I have have the new chassis which was made to suit the boss engine there is a chassis support in the way.
Thanks Les for passing the thread on.
Thanks Jason just like a real King. Remote is underway.
Chris.
08-02-2004, 06:46 AM
Zzz
Easy out
I think its far easier to get at with remotes
Chris the remote is the way to go, I think as it allows you the option of running a traditional setup for oil coolers at the front.
I used the remote myself and will update the oil lines to the braided that I have had stored.
Bernie
Bernie Knight
08-02-2004, 10:10 AM
NC
Cobra Make, Engine: 1983 Aurora - 302 Five speed- Jag rear -slab side FIA
The standard filter for some 302's is the FL-1 but it's too long for my Aurora Cobra. Used NAPA 1068.
08-03-2004, 07:03 AM
Chris
Myself and AC514 have a ford motorsport filter adapter which turns the filter 90 degrees to the eng block, we also had the same problem as yourself . Im sure Gino purchased it from ford racing performance parts distributor,RACEPARTS AUSTRALIA in queensland ph 07 3807 6870.
If it doesn,t rain i will bring the car to the mercat thursday
It fits as easily as an oil filter.
Bill Davies
