Old 08-14-2004, 11:19 PM
BJ's Snake's Avatar
Default crash pad
Hey guys,
Have been informed that I have to Have A padded crash pad on the leading edge above the dash.Does anyone know if they have to be a specific size and or can you buy them already done or do have to get them made. I have read the adr/21 but it doesn't say any sizes.Any input would be appeciated. Cheers
Brett
Old 08-15-2004, 12:04 AM
Cobra Make, Engine: Future
Question Impco Gas
Hi Brett, Was curious if your running propane? I noted you referenced an Impco gas feed. Sorry I don't know about the dash pad. Was considering running my Torino (428 CJ) on propane. Dave
Old 08-15-2004, 01:04 AM
Cobra.au's Avatar
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Hi Brett,
Who is your engineer?
I don't know anyone on the Central Cost who had one on their car when it got passed.
Sorry I can not help you with your question as I never had to cross that bridge but it dose seem to depend what side of the bed the engineer got out of in the morning as to what he will make you comply with.
Just my 2c
Craig W
Old 08-15-2004, 03:16 AM
Cobra Make, Engine: RCM, 302 Windsor EFI
Hi Brett
In vic we need a pad from passenger side.To just past the left hand side off steering wheel.Use double sided tape so you can remove after the engineer.
Old 08-15-2004, 03:40 AM
demicobra's Avatar
Cobra Make, Engine: Under re-construction
Post
Brett,
DRB in Brisbane sell them pre made for their Cobras.
If you ring Peter he can probably give the specs &
sell you one.They are a requirement for rego in Qld.
The number is 07 38072480
Regards
Nick
Old 08-15-2004, 03:02 PM
pneall's Avatar
Brett,
I used a section of insulation for water pipes available from hardware/plumber store. Its about 40 mm dia and already split along length so goes over dash edge real easy. Comes off easy too.
Phil
