November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-19-2004, 04:03 AM
Cobra Make, Engine: Classic Revival, LS1, Shift kitted auto, high stall, AU LSD rear.
Default Flash dash
I have just looked at PCC's gallery and have seen his dash.
Has anyone else gone down this path?
PCC ahve you anymore photos of how you mated the XR dash to your cobra?
Also I read in an earlier posting that you were having trouble with a couple of the guages. I worked at Ford in Geelong as an apprentice and was talking to a freind who is still there in product development , if you could tell me your drama my contact said he may be able to help.
Gav.
Old 11-19-2004, 05:40 AM
Gav .. Petes dash is pretty fancy and is standard fitment to the DRB 2000 series cobras.
Well...Maybe his is a little fancier but the DRB 2000 dash uses that moulding.
http://www.drbsportscars.com/frames.htm
Select Cobra, then DRB2000 and you can check it out..
Old 11-19-2004, 06:53 AM
PCC's Avatar
PCC PCC is offline
Hmmmmmmmm,
The layout has changed since DRB's photo's.
If anyone goes this way check that the bloody glove box fits well - notice its not installed in the photo
The AUI cluster is a straightforward fit into the dash. However a few mating problems with the chaser cluster and NC computer:
1. The tacho reads approx 500 rpm too high - who cares as you listen to the engine anyway; and
2. The water gauge is erratic - tried to fix with an additional diode, but got tired of getting to work anyway. Hence, a couple of new Stewart Warner gauges for x-mas (Symmetry issue).
Also the sppedo head died whitch EMP fixed (apparently common on AU's - bloody Fords)
PCC (Peter Craig)
Keep the sun shining
Old 11-19-2004, 06:55 AM
PCC's Avatar
PCC PCC is offline
Shocking typing - too much red wynne - Sorry
PCC (Peter Craig)
Old 11-20-2004, 02:23 AM
Cameron Parsons's Avatar
Too much Red Wine...
I wasn't aware that was possible
Cameron
Queensland Cobra Car Club
Wisconsin USA Chapter
ex: Beijing Chapter Member
Old 11-22-2004, 12:14 AM
PCC's Avatar
PCC PCC is offline
Cameron,
When you're drinking magnums - yes it can be a problem.
Talking of problems - is that Superformance beast heading north yet?
My offer still stands
PCC (Peter Craig)
Old 11-22-2004, 03:17 AM
The only problem is getting the straw to the bottom
As for the beast... It should be ready next week. But I won't be able to get to it at the ealiest until about the 8th
If miss that date, it will be February
Thanks again for your kind offer, no doubt the fastest way to the coast is via the no limit roads in NT...
Cameron
