Old 04-16-2005, 01:42 AM
Cobra Make, Engine: 1st Harrison with Gen 3 , 6 speed ,Godzilla diff & brakes
Unhappy LS1 trouble
Hi All ,
I just got my exhaust done (will post pics soon) but the problem i am having with the motor is that the Left Hand Sidepipe after about 1-2 minutes will be glowing red . The motor has a consistant miss have you guys got ant ideas for me .
All the plugs are new and they all fire as i have tested every one on there respective leads . I pulled the fuel rail of and turned it upside down then reconnected the injector plugs and turned the key and all the injectors are squirting . Fuel pressure is set to 55 psi or 380 killopascals .I also swapped oxygen sensors to no avail
Any Help would be much appreciated.
Paul
Old 04-16-2005, 04:54 AM
boxhead's Avatar
My guess is the rubber gasket seal on the intake manifold is not sealing correctly or the map sensor seal is leaking.
Glowing exhaust is normally a lean condition, are there any trouble codes coming from ecu?
Cruising in 5th
Old 04-17-2005, 02:54 AM
I added pic of exhaust to my gallery .
Well i done compression test and the left bank was all over the place ranging from 125 to 175 and funnaly enough the right hand bank had 2 cylinders with 0 compression . The front 2 rocker arms had spat the bearings so i will be pulling it down i guess .
Paul
Old 04-17-2005, 11:11 AM
Yetiman's Avatar
Cobra Make, Engine: Arntz/SBC/Jag
Ouch
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
Old 04-17-2005, 02:26 PM
Tenrocca's Avatar
Man. That'd break your heart. Im guessing its not a new one then. At least Im hoping its not.
Old 04-17-2005, 02:43 PM
pneall's Avatar
Paul,
Thats not good to see. The LSI is a pretty tough motor so it looks like whoever owned it before gave it a hard time.
You will probably find that a rebuild is pretty expensive and a new motor from Eagle may be more economical.
Its probably better you found out now rather than after the painting and trimming was complete.
Hope it all works out OK.
Phil
Old 04-18-2005, 03:42 AM
I rang the wreckers that i got the motor from and they are going to fix it
Could have been costly
Thanks for the help guys
Paul
Old 04-18-2005, 02:44 PM
pneall's Avatar
Paul, thats good news. You are lucky you started the motor before you finished the Cobra.
Phil
Old 04-19-2005, 12:48 AM
Yes i'll say
He has done the right thing by me because i got the motor over 12 months ago and there warranty is 3 months but we did discuss when i got the motor that it probably wouldnt be started for a year or so and to his credit he is being good about it
Paul
Old 05-30-2005, 05:09 AM
Hi All
Just letting you know that i got a call from the wreckers today and they have fixed my motor and it has cost them nearly 3g to fix the damage and he is chargeing me $150 to cover some of his labour costs . I must say that if anyone is looking for a motor and are concerned about warranties etc then go to All Panels and Parts and they will definetly look after you .
http://www.allpanelsandparts.com.au/index1.htm
Regards
Paul
Old 05-30-2005, 05:42 AM
What in the world on that engine cost $3k to fix?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 05-30-2005, 05:48 PM
pneall's Avatar
Paul,
Glad to see that worked out OK for you. Nice to know there are decent suppliers in the motor trade.
Will you be ready for the Nationals?
Phil
Old 05-30-2005, 10:12 PM
BMK's Avatar
BMK BMK is offline
Paul
That was a bit of luck with the guys helping there. Looks like a great yards they have.
Did they say what was wrong that cost $3,000... (Asked by Blykins sorry)
Ford Quad cam 4.6....
Bernie
Bernie Knight
Old 05-30-2005, 10:27 PM
pneall's Avatar
Bernie,
Probaly wasn't all that much wrong. Labour seems to be the killer these days.
Hows your rebuild going?
Phil
Old 05-30-2005, 11:23 PM
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
not surprised at $3000
If you got all the parts required to build a 302 from ford it would cost $9000 just for parts. The newer the motor the less after market options.
Sounds like your supplier was very good
Cameron
Rate This Thread:
