Old 05-02-2005, 12:40 AM
Aussie Mike's Avatar
Default We have the technology...
Well here's the first of the goodies I brought back with me from China.
With all the Hoo-Ha going on about exhaust noise and emissions etc I thought I'd better get myself some test equipment.
This is a digital sound level meter and it's a neat piece of kit. It's got some cool features like being able to filter out background noise and a max hold feature. Max hold means I can set it up and then hop in the car and do a run up then hop out and se what the peak reading was.
I figure if I'm building side pipes then I'll want to know what sort of results diffeent baffles give.
The Ute did 89.2 dB at 1 Meter on a run up to 3000 RPM.
I'll post some info on the other new toy once I've set it up.
Mike Murphy
Melbourne Australia
Old 05-02-2005, 01:15 AM
Mike, Other new toy?.
do ya blow it up?
Battery powered or mains power?
Does it vibrate?
Does it wriggle or just go round and round?
C'mon...you can tell us
Old 05-02-2005, 02:11 AM
boxhead's Avatar
Stop buying little toys Mike and get that big one finished
Cruising in 5th
Old 05-02-2005, 03:19 AM
302cobra's Avatar
Cobra Make, Engine: Modified DRB 2000, 302 Windsor
Is that your ute??? I thought you were a Holden man, since your putting a Holden/Chev engine in your cobra?? I dont mind Chev, But if its a Holden, No way!!!!! He He!!!!!
Old 05-02-2005, 03:44 AM
Yep the Ute is my daily driver. I've always liked Fords and I've owned 6 of them over the years. I also like the products from a lot of other manufacturers and I try to take each of them on their own merits.
My LS1 came from the US and was from the Camaro/Firebird but it's pretty much the same motor used in the Aussie cars.
The other toy is a machine I've wanted for a while. I've been joining bits of metal together for years now I'll be able to cut them apart as well. I picked up a 40 Amp plasma cutter. This is about the biggest machine you can run off a single phase and will cut through 8mm steel plate no problem.
Plasma Cutter
Mike Murphy
Melbourne Australia
Old 05-02-2005, 05:08 AM
boxhead's Avatar
Mike, your like a kid in a candy store.
I can just imagine your eyes as wide as a saucer.
Cruising in 5th
Old 05-02-2005, 05:16 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
When you come to the states, you will need to stay away from Harbor Freight tools.
Old 05-02-2005, 05:24 AM
I love the engineering shops over there and they are all usually in one district in the citys. You can spend a day or more wandering up and down the countless shops looking at all the goodies. Heaps of machines for every job and the quality is getting pretty good now.
There were some nice looking tube benders that produced some excellent results in thin wall tubing. A neat design that could turn a 6" diameter coil of 1/2" SS tube of about 4 or 5 turns.
I nearly bought a new TIG welder but I had a bit much bagage and equipment with me and didn't want to pay the excess baggage. I found a nice AC/DC unit that produced nice results on Aluminium but it was about 25-30KG. Maybe next time I'll pack extra light when I go over.
I found the site for the company that made the plasma cutter. It looks like it'll actually cut 16mm steel plate which is a nice surprise as I was trying to read the Chinese brochure and thought it was only 8mm.
Here's the correct web page: Rilon Industry Co
Mike Murphy
Melbourne Australia
Old 05-02-2005, 05:29 AM
This is the TIG I was looking at:
WSE 200 AC/DC Tig Welder
Mike Murphy
Melbourne Australia
Old 05-03-2005, 09:00 PM
justbetter's Avatar
Cobra Make, Engine: Superformance AUS002, Chev 5.7 with hairdryer
Default Carry On
And all that folks in his hand luggage...
Garrett
COBTHS
Superformance SPF AUS002 "Modified"
Old 05-05-2005, 03:00 AM
302cobra's Avatar
Yeah, Nice ute Mike. Ever thought about trading to a BA??? It seems you like toys a lot, so that could be another new one in the garage!!!! Those BA's are superb, particularly the control blade IRS, it makes for a brilliant ride. I heard that a guy actually put one of those setups into a Cobra, man I bet its real comfy!!! Now if only the BA's could ditch a few hundered kilos they would be perfect!!!
Your ute is not a Pursuit is it?? Its got the wheels and the body kit though!!
Old 05-05-2005, 03:16 AM
No, just a couple of 3500PSI liquid filled pressure guages in my hand luggage. Got some attention from the airport security people who wondered what they were for.
I'm fitting one up to my hydraulic press so I can can calculate the tonage.
Mike Murphy
Melbourne Australia
Old 05-05-2005, 03:19 AM
Yep it's a genuine Pursuit 250. The last and the strongest of the Windsors. It's the same motor as the TS50 a 347 with billet rods.
The Pursuit 250 actually turns the 1/4 faster than the new pursuit 290 thanks to it's lower weight and torquier motor.
I was originally looking at a BA ute when I bought the Pursuit. The pursuit just added up to a much better package for the money.
Mike Murphy
Melbourne Australia
Old 05-06-2005, 04:58 AM
Cobra Make, Engine: The one leaving fat black marks
I'm really embarrased now. I only brought home a few "T' shirts, a brass Buddha...
I did get a chance to check out the industrial supply shops in Beijing just to much to choose from...
Bernie
Old 05-06-2005, 04:01 PM
justbetter's Avatar
Thumbs up losing it
Bernie your loosing posting points by logging in under Todds name.
Me
Garrett
COBTHS
Old 05-06-2005, 04:57 PM
boxhead's Avatar
Todd has never been so active on the boards.
Cruising in 5th
Old 05-06-2005, 04:59 PM
302cobra's Avatar
Mike, How come it has the XR8 Badges?? And doesnt the hard deck cover usually have a wing as standard?? I have seen AU Pursuits here in NZ and they dont have XR* Badges (if I remember correctly) and they had a wing. Whats Up???
Old 05-06-2005, 06:56 PM
The wing is an option that most people usually take up but this one was ordered without one. I have to say I've never been keen on the wing, it makes the rear end a bit busy looking so this suits me.
The AU3 Pursuit 250s were built by Ford as part of the XR8 family unlike the TE50 and TS50 which were built under the Tickford banner. Concequently they all had XR8 badging. I'm not sure why they did this but the BA Pursuit is now built under the FPV banner along with the GT, GT-P and Typhoon.
The AU2 Pursuit was just a standard XR8 with a body kit and different wheels. I believe this was a dealer option. The AU3 Pursuit 250 was factory built and was a lot different to the regular XR8 ute.
They run a lot of the runnng gear from the Tickford TS50. including the engine and trans, Premium brakes, lowered suspension etc. They were also available in the colours the regular XR's weren't available in. The Blueprint paint on mine was a Pursuit or Tickford only colour till it was later released on the BA. The Pursuit 250 is also fairly rare with only 250 built. I guess some people may have removed their XR8 badging.
Mike Murphy
Melbourne Australia
