questions
- » Blogs
- » Image Gallery
million posts!
January 2026
| S |
1 |
| 4 |
5 |
8 |
| 11 |
12 |
15 |
| 18 |
19 |
22 |
| 25 |
26 |
29 |
30 |
31 |
07-04-2005, 12:27 PM
Senior CC Premier Member
CA
Guys,
For your FE's, especially running solid / flat tappets, see Crower's comments (literally) below. They're not big on synthetics:
Use of Synthetic Oils
Crower does not recommend the use of synthetic motor oils in any racing applications, particularly hydraulic and flat tappet camshafts. The minimum gains in horsepower are offset by the excessive wear to cam and lifter surfaces. Crower recommends Kendall GT-1 (20W50) Petroleum based motor oil in all high performance applications. If your manual suggests running synthetic oil, then do so. We have found, however, that the benefits do not outweigh the costs.
© 2005 Crower Cams & Equipment Co., Inc.
Phone: 619-661-6477 · Fax: 619-661-6466
Regards,
-Michael
06-01-2008, 08:06 PM
az
Cobra Make, Engine: RF GT40
Valvoline Durablend
07-04-2005, 02:38 PM
http://www.tirecradle.com/tips.htm
For a more analytical treatment on the subject, click on the above link.
07-04-2005, 03:14 PM
IL
Cobra Make, Engine: Everett-Morrison, 434 cid
Originally posted by Bernica
Guys,
Regards,
-Michael
Crower was big on Kendall GT-1 20w-50 Racing Oil until it was reformulated a couple of years ago and doesn't contain the same additive package.
I know Crower's site still recommends Kendall but, if you talk to Dave Crower, he's been saying to use the Schaeffer's Supreme 7000 20w-50 Racing oil. But, yes Crower is dead set against synthetics.
07-04-2005, 03:50 PM
WI
Thanks for the replies...
Mobil 1 seems to be a favourite.
Cameron
07-04-2005, 06:47 PM
VIC
All this Synthetic and mineral based stuff is crap.
I've gone completely organic. It's nothing but Extra Virgin Olive oil with a V8 Vegetable juice adative thrown in for some extra get up and go.
It's environmentally friendly and the car smells like an Italian resurant.
Warning: Not to be taken seriously.
Mike Murphy
Melbourne Australia
07-04-2005, 06:51 PM
Wi
Cobra Make, Engine: Arntz/SBC/Jag
ROFL  )
07-04-2005, 07:17 PM
Castrol 20-50.
07-04-2005, 07:24 PM
VIC
This got me thinking a bit about vegetable based oils in engines.
A friend of mine years ago used to run his 2 stroke race bikes on methanol and castor oil premix. You had to mix it up fresh as it didn't like sitting in the tank but it produced significantly less wear than any of the mineral based oils at the time.
Smelled good too.
Mike Murphy
Melbourne Australia
07-04-2005, 11:17 PM
CA
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
I use to use Mobile 1... To be honest I am a little confused about their new formulations and really hate change...
So Now I use Red Line 20/50.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
07-05-2005, 02:29 AM
Q
I have always used Castrol. It used to be GP50, then it was changed to Formula R. Always 20W50. While dyno tests have generally shown slight power gains with lighter oils, I have found that the oil has saved me from costly repairs on a couple of occasions.
1. The 460 in my Fairmont had massive oil surge at 6000+ rpm while I was braking from VERY HIGH speed at the drags. I was at 0 oil pressure for about 6 seconds. The bearings were inspected and shown to be as good as brand new.
2. I don't have an oil cooler or oil temp gauge in the Cobra. Before I had set up the Motec triggered idiot lights on the car, I took the car to Qld Raceway. The oil temp was over 260 degrees F, and oil pressure was unaffected. I was sure that I would have hurt bearings when I looked at the datalogging, but again - good as new !
Craig
06-01-2008, 05:21 AM
GA
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Amsoil Racing 2000 - 20W50.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
06-01-2008, 09:51 AM
wi
Cobra Make, Engine: ERA #726 427 SOHC
Any of the diesel oils; Rotella, Delvac, or Chevron. The synthetics are not cost effective at all in an older engine that is driven seasonally.
06-01-2008, 10:40 AM
SC
the diesel oils have all been reformulated and are little different from any other oil now.
http://www.lnengineering.com/oil.html
06-01-2008, 12:46 PM
oil used
Pen green 50w. Has all the addatives in it that was taken out of modern oils by the EPA.
06-01-2008, 01:41 PM
AZ
Cobra Make, Engine: Alum bodied CSX4266, fuel injected alloy 472, 663 hp Engine built by Dralle. Suspension by Tom Barnard
Brad Penn 20W-50 Racing oil, better known as the green oil.
Don't underestimate the predictability of stupid!
06-01-2008, 05:54 PM
CT
I use Shell Rotella.
06-01-2008, 07:56 PM
TX
Shell Rotella 15-50
6th generation Texan....
06-01-2008, 08:50 PM
CO
Motor oil is always a little bit of black magic. Mostly because the ingredients for each are a tightly held secret. With all the ad hype, it's hard to pick out a good oil. Here's my opinion, though:
Synthetic oils will handle abuse better than dino oils, especially heat. The additive package is usually more stable, allowing for a longer drain interval. And that's good, because they're more expensive.
The trick is picking out a good synthetic. The first thing you need to know is, what is a synthetic oil? In the beginning, a synthetic oil started with a true synthetic PAO base stock. A manufactured molucule, derived from natural gas. Semi-Synthetic oils started with a group III or IV base stock, which is derived from standard dino oil. Synthetic blends had a mixture of base stocks which varied from one oil to the next.
Fast foreward to 2008. Due to an interesting trick by lawyers and ad men, a synthetic doesn't mean what you think it means, or what it used to mean. Any oil that has been formulated to meet certain performance charectoristics can be called a "fully synthetic" oil. Even oils that start with a group III or IV dino oil can be called fully synthetic, as long as they meet the performance standards.
AFAIK, there are only three oils on the general market that are truly synthetic (started with a PAO base stock): Amsoil, Royal Purple, and Redline. That's it, only three. Notice that Mobile 1 is NOT one of the three. Mobile 1 is actually a semi-synthetic. It's not a bad oil by all accounts; it's just not what you think it is. Now it's getting cheap enough, I might consider using it again.
Now, how much oil performance do you really need? Royal Purple and Redline are probably the very best motor oils generally available. I use RP in my cobra, since it see's a lot of hard track miles. It's expensive, but worth it for this engine.
But, none of my other cars use it. Why? They just don't need that kind of performance for a daily driver. Many people here claim M1 is an excellent oil and they've never had any oiling problems while using it. M1 is a Group IV oil. That means that any "fully synthetic" group IV oil meets the same performance charectoristics. So, why pay $5.95 form M1, when I can get Penzoil, QS, Castrol, etc for $4? My daily drivers get QS. Probably more protection/performance than they really need, but reasonably priced.
Flat tappet cams have a real problem. As has been said, the diesel oils have been reformulated, so they don't have any zinc in them either. No matter what oil you use, you MUST include a zinc additive, or your cam won't last long. Comp Cams and Crane Cams have their own brand. GM used to sell one, but they dropped it. And I believe STP is mostly zinc, but I can't prove that.
06-02-2008, 04:01 AM
Group I, II & III mineral oil
Group IV PAO's
Group V Ester's
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
