Old 05-13-2006, 10:37 PM
RODA's Avatar
Cobra Make, Engine: Classic Revival LS1 6spd
Default Sway Bars
Hi Guys,
I am looking for some words of wisdom, on wether there is a need to have front and or rear sway bars.
I have notice some people have them and some don't.
If yes is the answers what are the best ones to use and where do I get them.
Rod
Old 05-14-2006, 05:16 AM
Philm's Avatar
Default Sway Bars
HI Rod,
I have a front sway bar but no rear and that seems to work well. I have heard that a rear bar may increase over steer.
I purchase mine from Ian, and It did not fit . I was actually told this by a fellow CR owner but had already had it organised.
Phil Neall has the best set up I have seen.
Phil
Old 05-14-2006, 05:20 AM
boxhead's Avatar
Come on then now Phil Neal, where are some pics and details.
Including price, contact details and fitting instructions
Cruising in 5th
Old 05-14-2006, 07:30 AM
Bryan Wilson's Avatar
Default Roll bar
I have a roll bar only on the front.
One day the watchamacallit/thingy that connects the end of the roll bar to the suspension broke
It broke while turning hard into a right hand corner and nearly speared me off the road.
The car handled like a wet sponge without it working.
If you look in my gallery you can see the bar under the car.
Bryan
VK3KDN
Old 05-14-2006, 09:05 AM
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
Bryan
After years of dreaming about what the handling would be like in one of these cars, the first drive after my build was profoundly disappointing, with no steering precision at all. But with the addition of a front anti-sway bar, it was like driving a different car, where handling reality lives up to the handling dream I carried for years. Now, even my Mustang, which I always considered to have very responsive steering, seems mushy. No matter what anyone says, remember that handling on these cars is what you make it. Keep experimenting.
Old 05-14-2006, 04:13 PM
pneall's Avatar
My front bar was made by local Pedders shop. I'll ask them if they kept the shape on file. It made a huge difference to the handling.Front bar is 19 and has a few adjustment points.I'll try to get a photo.
Planning to try a small rear sway bar this year.
Phil
Old 05-14-2006, 04:48 PM
RODA's Avatar
Phil,
If Pedders had any info that would be great.
There is A Pedders outlet not far from work. They may even be able to send the info there and they could make it, if they weren't keen on giving you the info.
Rod
Old 05-14-2006, 10:47 PM
Cobra Make, Engine: Superformance with 460
Phil, After speaking with several cobra owners, I plan on using a 1" sway bar on the front and a 3/4" on the rear. Jeff
Old 05-14-2006, 11:56 PM
Leeroy's Avatar
Roda
I originally purchased one from Ian but it didnt fit at all. I then made the the sway bar out of 20mm PVC rod (heatgun used to form its shape) then took it to Moorabbin Spring works and they made it for me. I have not driven without it so I dont know what it handles like without one.
Leeroy
Old 05-15-2006, 12:49 AM
PCC's Avatar
PCC PCC is offline
Someone show us a pic so I can see where it fits.
My Cobra needs some sort of handling improvement as she is light as hell at the front end (vague on rough roads) and that is with the Ford block in it
Bryan - couldn't see the pic in your gallery
PCC (Peter Craig)
Keep the sun shining
Old 05-15-2006, 02:21 AM
Ken Bisconti's Avatar
Junior Member
Cobra Make, Engine: Hurricane Cobra HM 1007, 390FE
I am also looking into a swaybar. I found this in the Hurricane Cobra website under owners form. http://www.vintageperformancemotorcars.com/
Old 05-15-2006, 06:13 AM
Cobra Make, Engine: classic revival 302w
Hi phil
if pedders have a part number for that sway bar we might be able to purchase it down here
cheers
jess
Old 05-15-2006, 08:04 AM
Cobra Make, Engine: Shamrock Cobra, Ford Cleveland 351-4V
In process of having front and rear sway bars fitted to my car this week. Bars are priginally from a Toyota Hilux. I will hopefully be able to update on how the car feels next week, in comparison to driving without them for the past 3 years. Suspension is Jag front & rear.
regards
Charlieh
Cobra - its all in the bite
Old 05-16-2006, 08:23 PM
pneall's Avatar
RODA. JESS.
Spoke to pedders today. They dont have a pattern or part no for my front bar but they are happy to make new ones if I take my one off and they use as a template.I have no problems with taking the bar off if you or any others interested.
Price is $275 + $20 delivery. Price will be lower if order number large enough.
Contact is Michael at Pedders Hornsby on 94776310
Phil
Old 05-16-2006, 08:52 PM
400TT's Avatar
Originally Posted by pneall
RODA. JESS.
Now that's a great offer for CR owners.
Phil, will different engines affect clearance of sway bar. eg different sumps. Are all LS1 engines mounted in the same location?
www.absolutepace.com
Old 05-17-2006, 12:20 AM
RODA's Avatar
Phil,
Thanks for chasing up Pedders.
I will give them a ring and find out what they need and when.
There is no hurry for the sway bar so when I get the info from Pedders I will let you know and you can do it when ever it suites you.
I think its fantasic that you prepared to do this. That whats fantastic about this forum everybody is so happy to help out when ever they can.
Thanks again
Rod
Old 05-17-2006, 01:17 AM
pneall's Avatar
Craig,
If its an LS1 in a CR then the motor position is predetermined.The only thing you have to be careful with is the position of the radiator hose connections as they are close to the sway bar.
Hope the GT40 build is going well.
RODA, No problem as long as its not the weekend before the Nationals
Phil
Old 05-17-2006, 02:52 AM
Cobra.au's Avatar
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Put me down for one if there is enough people to do a production run to get the price down.
Craig W
Central Coast NSW
Old 05-17-2006, 03:58 AM
boxhead's Avatar
I will also take a sway bar, at that price or reduced price still sounds like a bargain to me.
Cruising in 5th
Old 05-17-2006, 08:48 PM
pneall's Avatar
I am having a Cobra builders BBQ at my place on 23rd and may pick up a few more enquiries . Once sorted I will get final price off Pedders and place an order. I will leave financials between yourselves and Pedders.
Phil
