05-26-2006, 11:34 PM
NS
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Ian fitted a rear bar to mine (without asking for it) and it seems to be the standard ford one that came with the new diff.
Craig W
Central Coast NSW
05-26-2006, 11:38 PM
NS
Hi Phil
(Pneall)
would you know the distance between mounting eyes (left & right wishbone) as I am concerned with the differant wheel offset between my car and the newer version CR.
Craig W
Central Coast NSW
05-27-2006, 04:41 PM
NT
Hi Craig, from what your saying it appears you have the earlier type rear sway bar mounting points (I was thinking of welding in some brackets to mount the Ford sway bar)
The sway bar mounts on my chassis are down below the front of the diff snout.
Cruising in 5th
05-27-2006, 07:33 PM
VIC
Craigs car is the generation just before ours. It has pretty much the same chassis but Ian moved the front suspension pickup points out about an inch on both sides on our kits. This was to reduce the scuff radius on the front wheels. If you look closely at the pics of craigs car you will se he has more dish on the froth wheels than the later cars.
Rear sway bar mounts are for the factory Ford Au rear bar. Dont make the mistake I did of buying an after market bar because they are a different shape and hit on the diff mounting. The only problem with the Ford bar location is that it's a bugger to get to.
I think Ians newer cars run rear sway bar mounts on the bottom of the chassis and run the bar under the lower control arms.
Mike Murphy
Melbourne Australia
05-28-2006, 03:00 PM
NSW
As soon as I have finished playing with the Cobra over winter I'll get the rear bar sorted. On my CR the mounting tabs are on the centre chassis extension facing in. I think out may have been better.
Craig , I'll check dimension and let you know tomorrow.
Phil
05-29-2006, 01:46 AM
NT
It sounds like you have the same rear sway bar mounting points as I do Phil.
I did think about welding some tabs in place to mount the ford bar.
Cruising in 5th
05-31-2006, 12:21 AM
NSW
Craig,
Hope I have measured the right part.
The distance between the sway bar link points on the bottom wishbone is 1130 when in the fully droop position.
Phil
06-03-2006, 05:06 AM
NS
Thanks Phil
Got back from Taiwan today, I will get the measuring tape out tomorrow and check.
Craig W
Central Coast NSW
06-07-2006, 08:49 PM
NT
I just got a call from Pedders, my bar is on its way
Thanks again Phil
Cruising in 5th
06-07-2006, 09:27 PM
NSW
Cobra Make, Engine: Classic Revival. LS1, T56, Billy Cart
They look good
Boxhead,
I picked mine up on Saturday and they look really good. The mounting centres line up with no issues.
Only thing I have to work out now is how to fit them to the Jag flat bar.
06-07-2006, 09:55 PM
NSW
You need a couple of thingies like Phil Had on his  There was a threaded bit, and a couple of round balley things, and another bit I dont know the name of either....
Aint I a great help
06-08-2006, 01:08 AM
Vic
Cobra Make, Engine: Classic Revival LS1 6spd
Box Head
Pedders must be doing a bulk delievery today. Micheal rang to say mine was on the way as well. He said he had made 10 of then.
Phil,
Once you finish designing your rear one, we can all place an order again. I suggested that he should give your rear one for nothing, because if it is right he have another order of 10 for the rear.
Thanks again for all your help.
Rod
06-08-2006, 02:37 AM
NSW
Mine looks great Phil.
Thanks for setting up the deal.
Ben
06-14-2006, 02:19 AM
vic
Cobra Make, Engine: classic revival 302w
Got mine today nice job thanks again phil
cheers
jess
06-14-2006, 03:43 AM
NT
Mine arrived yesterday, Thanks again Phil
Cruising in 5th
