Old 08-13-2006, 02:55 PM
Cobra Make, Engine: Classic Revival 3506
Default CR alternator bracket
Does anyone have a template for mounting a alternator to a LS1 in a CR kit.
Without having to notch the chassis.
Any help or pic's would be great.
Thanks Paul
Old 08-13-2006, 03:39 PM
venom0427's Avatar
paul, i made a kit a few years back for a LT1, it was a small nippondenso alternator around 70 amp, and we made it so it would fit up close to the engine, if you like you could try it out and see if it fits.
the only problem is that it a bit rusty, but nothing like a bit of a scrub won't fix
Old 08-13-2006, 03:51 PM
Cobra.au's Avatar
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
ptrefry
I still may have the template floating around somewhere for my setup but I used a Corvette motor which buts the 6pk belt in a different position than the Holden ls1
Craig W
Central Coast NSW
Old 08-13-2006, 04:21 PM
Leeroy's Avatar
I machined a simple alumin. bracket which mounts on the opposite side to Craigs. Pic is a bit hard to follow but gives basic idea. The altenator form GM is probably way overkill for a cobra and I think many of the guys run smaller jap ones. Cos you will need to make bracket I would go for something smaller & cheaper as the GM ones XXXy.
Old 08-13-2006, 04:23 PM
Leeroy's Avatar
Craig
that is one awesome looking motor you have there. Sure must have been some head scratching trying to make it all fit. Also how do I attach pictures as you have with your post ?
Leeroy
Old 08-13-2006, 05:01 PM
Aussie Mike's Avatar
The minimalist approach
The alternator is an 80 Amp Delco unit sourced from a Japanese import wrecker ($55). Pulley is home made along with the mounting bracket.
The bonus was selling the original alternator for $150 which paid for all my materials.
Mike Murphy
Melbourne Australia
Old 08-13-2006, 11:37 PM
Thanks guys for all the help
