January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 11-07-2006, 02:54 PM
400TT's Avatar
Thanks Geof, I knew you had the details.
I've dug out your pics.
Definitely an easier job in a Harrison as they even provide you with the top mount for cable(if you are fitting 302w & T5 combination).
www.absolutepace.com
Old 11-07-2006, 08:22 PM
Cobra Make, Engine: DRB - 302, T5, VN Rear
Craig,
Did you use the modified Torana clutch pedal ? Where abouts did the cable enter into the drivers cabin - in the tunnel, up through the floor ?
Looking at GeoF's photos his cable enters through the firewall, but there is no room on the drb due to the brake booster.
Thanks for your help,
Dan
Old 11-07-2006, 08:48 PM
400TT's Avatar
Yep, just shortened a Torana clutch pedal as per manual.
Can't remember where the clutch cable entered now, we would have just followed the instructions in the manual. Just had a look, no other photos I have here help with where it went.
