| 29 |
03-09-2007, 01:32 AM
Qld
Roll Cage
The cage is coming along as you can see by the pics below.
The diagonal bar on top is going to be reworked so that it is flat and wil then bend down into the front corner. There will also be another that will run the other way to form an X over the top.
As you can see the cage is as out board as possible and I have 2 door skins that I will hinge as doors, this will alow me to cut out the holes for the posts.
I am reworking the hinges for the normal doors so that I can remove the pin and remove the doors, this will allow me to keep the position when they are removed and reinstalled. That is why I wanted the door striker to remain, I don't want to have to refit the doores every time I put the cage in. This may be ok now but when it is painted it may be a little different.
There is still the taxi bar to go just above the back of the seats and the 2 rear stays.
I am very please with the look of the cage but also the workmanship, I will take some photos of the welds, absolutley perfect.
It should be finished on Tuesday I will post some more pics then.
I will appreciate your comments as if there is something I have missed now is the time to let me know.
Phil
03-09-2007, 01:42 AM
NSW
Cobra Make, Engine: Robnell BB 429 (Sold) Contemporary Cobra CCX3682
Impressive!
Phil, That is one impressive cage you have there, as I don't know much about the logistics of how a cage would best be effective, I will give it the thumbs up anyway!
Lame I know!
Stef
Life really is beautiful!
03-09-2007, 03:17 AM
NS
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Looks Like you will have to rework your doors a little.
I am watching with great intrest
Craig W
Central Coast NSW
03-09-2007, 04:20 AM
NSW
One awesome Cobra Phil.
How about you give that ride a coat of paint so it looks as good as it is put together!!!
Hopefully you can still run your top with the cage, it would be awesome to have that protection without the distraction of those bars.
Ben
03-09-2007, 04:33 AM
Qld
The best fit
Craig,
I will not use the regular doors when the cage is in, I have door skins that I will use. I will post some pics on tuesday that will demonstrate what I mean.
Beejay,
We almost made that work with the soft top, but there were just to many compromises. You can put the top on and use the cage as the bows but it is not perfect.
The idea is that the cage will be used when racing, it will be install and then we will trailer the car to an event. I will get a cover made for weather protection.
Phil
03-09-2007, 07:47 AM
BC
Door bar
Hi,
Good so far.
You will need a higher driver side bar, the drag racing spec is for the bar to be 1/2 way between shoulder and elbow,but the inspector likes it on the high side.
Perry.
03-09-2007, 03:31 PM
nsw
Cobra Make, Engine: CR 3205
Monkey bar heaven, looks awesome Phil lets hope you never need to put it to the test.
03-09-2007, 04:16 PM
NSW
Cobra Make, Engine: Homebush. Lexus quad cam V8, R154 Supra box. Oh what a feeling.
Phil
What does the Queen think? Are you going to chrome it?
Brett
 !!Its good to be stroked but i'd rather be blown!!
Proud member of the Bclub Central Coast chapter
03-09-2007, 07:28 PM
Qld
Cobra Make, Engine: Now built a race cobra.
looks Great Phil.
Hi Phil its about time more people took their safety a bit more serious. not just for drag racing but circuit racing too.
i recon it may make the car heavier but you will go faster confidance is a lot when go flat thru the kink a wakefield.
Yeha..
oz.
03-11-2007, 10:59 PM
WA
This looks encouraging for me... I like the idea of only putting one extra hole in the body for the second backstay, (I assume the other backstay will go through the existing 3rd leg hole). I'll have to check out how the four points inside the cockpit will go but as Big Kev always said, "I'm excited"...
I'm very keen to see the finished result, it's looking good Phil.
03-20-2007, 06:54 AM
Originally Posted by Shelby400
Phil
Brett
Me thinks the queen will love it.
She'll be able to take it shopping and dry the washing all at the same time.
Looks great Phil
04-01-2007, 06:36 PM
Qld
Cage Update.
04-01-2007, 06:48 PM
NSW
"LS1 Kills"...  ROFL
Looks awesome phil. You look nasty with your helmet on!!
03-12-2007, 07:42 PM
Hey Phil...a question? Does the bar running down beside your noggin worry you? The pro's know what's the go but I thought I'd ask what they thought about it?
SpookyPT
03-12-2007, 08:23 PM
Qld
Trick Photography,
HI Matt,
I understand what you are saying, I am going to pick it this afternoon and I will post lots of pics, some with me in the car.
The angle of the pics may be a bit misleading, the top secton of the main hoop is behind my head.
Yes now I am concerned!!!
Phil
03-12-2007, 08:34 PM
Phil, mate I am only highlighting this as a question as I don't want to see anyone getting hurt and I hate anything being close to my head... I notice on the Cobra Race Cars in the USA that the upright is actially flared out quite a distance... My question may be unfounded as the pics may not show the angles of dangles properly but certainly once you sit in it with a helmet on and strapped in you'll get a good idea how close it is to your noggin!
Keep us posted!
SpoookyPT
03-15-2007, 08:07 PM
Qld
Bugger!!!!!!
03-19-2007, 05:59 AM
WA
Looks good Phil, some of the 25kg's will be offset by the lightweight doors too... I like it!!!
03-20-2007, 02:25 AM
NSW
Phil baby !
safety comes first always , But ! you've spoilt the car.
Take it off and just go a little slower !!!
03-20-2007, 06:42 AM
Qld
Look a bit harder
Peter,
The cage is completely removable, the only thing that will give it away is 2 50mm holes on the rear deck.
The cage takes about 30 to 40 mins to install or remove. I would never drive on the street with the cage installed.
I will still look pretty out on a cruise.
Phil
