February 2026
Old 05-26-2007, 11:27 PM
Tenrocca's Avatar
Default Boot Progress
few pics of the progress Ive been making on the boot - the brushing (scotch briteing) and polishing need a little touching up after installing - but Im pretty happy with how its come up.
Few more pics in my gallery
Old 05-26-2007, 11:59 PM
BMK's Avatar
BMK BMK is offline
Tenrooca
Looks great mate. Puts my effort to shame. Think I will need to do some work and upgrade..
Bernie Knight
Old 05-27-2007, 12:01 AM
boss290cobra's Avatar
nice andrew although you would have to be careful when putting something in the boot
nice result
darrell
Old 05-27-2007, 12:04 AM
Tenrocca's Avatar
Bernie, I dont have a big blue bottle of laughin gas through
Darrell - I am planing to have a piece of carpet made up for the floor , and a couple of tie downs _ Mike suggested some nice Aluminium luggage
Old 05-27-2007, 12:05 AM
BMK's Avatar
BMK BMK is offline
"Officer that's a fire extinguisher system Sir"...
Bernie Knight
Old 05-27-2007, 12:07 AM
good idea ,would you do the carpet in a similar style,that would look great
darrell
Old 05-27-2007, 12:09 AM
andrew who done the work for you
Old 05-27-2007, 12:12 AM
BMK's Avatar
BMK BMK is offline
Tenrocca,
Now Aussie Mike is nearly finished his car, so he should be good for a few small jobs at home. Louis Vitton and Aussie Mike suitcases in the boot..
Bernie Knight
Old 05-27-2007, 12:22 AM
Tenrocca's Avatar
Hey Darrell, Im planning just black carpet, but where the stripes are have the carpet just turned on the grain - subtle. I did the work myself - Im no expert though, just more time then money! haha. Shaun made the battery box - top work as usual.
I should pop over and see your car now shes arrived.
Cheers.
Old 05-27-2007, 02:12 AM
yeah sure im home every weekend just drop me an email when u like, i will get the steering components this week and install on weekend,my neighbour is preping the body for a shadow coat,then the braking assembly that'll be fun
darrell
Old 05-27-2007, 06:39 AM
I've seen a couple of classic revival boots and I am very curious about the seatbelt mount set up and adr aproval as mine had to be built like a leg of the sydney harbour bridge. What's the story ?
Old 05-27-2007, 03:46 PM
Tenrocca's Avatar
AS far as I know no engineer has had an issue with the seat belt mount. A lot of people have beefed it up a bit with a sheer plate. I know of one CR crash and and the driver survived....so thats good enough for me. haha
Old 05-27-2007, 04:15 PM
Very nice work Andrew.
How did you end up doing the bends and curves?
It turned out so good you will have to do the engine bay.
Ben
Old 05-27-2007, 04:35 PM
Tenrocca's Avatar
Thanks Ben - I made a bending brake a while back from some plans I found on the net:
It does an OK job on 1.2mm aluminium but I wouldnt want to go much thicker. The large curve I just bent around a fence post till it was about right! I made up lots of cardboard templates first though.
The engine bay is next.
Old 05-27-2007, 06:04 PM
Cobra Make, Engine: Classic Revival (CR3204) 6ltr s/c, T56 6spd
Nice work Andrew.
Love the pollished stripes in the boot
I've been bust doing similar treatment in the engine bay along the fire wall. Still got a bit more elbow grease to put in to finish it off, but its getting there
BTW, do you have a sketch or drawings of the battery box. I might have to get Shaun to make me one as well
Old 05-28-2007, 03:25 AM
nice andrew good to see it finished, different approach which is always good, looks better than i imagined. box and stripes look great.
Old 06-01-2007, 07:34 AM
Yess! the cardboard template. Mine are all out of beer carton ( you have to empty them first) I almost have a complete Cobra made of cardboard !
Old 05-27-2007, 06:31 PM
Tenrocca's Avatar
Nice work Luke - Love the look of aluminium in the engine bay.
I made up a cardboard mock up of the battery box for Shaun, but I stuffed up a bit. I had it tucked nicely under the seat belt mount, but then realised (once I had cut the hole in the boot floor) that although it looked great, once the battery was in I actually couldnt lift the lid off over the battery (Number one in the dumbest things Ive done on my car so far) So I moved it further back (and patched the hole), but then it fouled wth the chassis cross member, so had to have Shaun cut the bottom off the bottom section and make it a bit shorter - Ill measure up tonight the final dimensions - I plan on using an Optima battery (like many) so sized it accordingly (I hope!)
Old 05-27-2007, 07:06 PM
Thanks Andrew,
I've actually used stainless in the engine bay. I wanted something a little more hard wearing in the engine bay and I got the sheet of stainless at a price a couldn't refuse
Like you mentioned, I also made extensive use of cardboard to make up templates and then took these down to my local sheetmetal place for cutting/welding etc.
Old 05-28-2007, 04:26 PM
Gav's Avatar
Gav Gav is offline
Lovely work guys, I'm quite jealous.
Makes mine look VERY basic and I'm not happy about it!!!
I agree with you Mike the tail lights do need a cover, I need one, due to the tail lights I'm using being open in the back with the lamp exposed. Although it could be handy if you want a boot light, hit the brakes and presto!
Gav
Powered by Cu
