Old 09-08-2007, 04:58 AM
Default L76 looms for shipps and rebel1
to rebel1 and shipps
started making looms for the l76
rebel1 i need yr engine loom to mod
plus yr gearbox plugs
shipps loom is 80% done
i have bought new micro relays they are half the size of yr normal relay
only afew bucks more expensive but it makes the whole job neater
most loom makers still use the big normal relays
i have started using the micro relays that are half the size
so i hope to have abit more room under dash or easier to fit
i can use micro relays on complete body looms but price goes up abit
anyway when u read this send us an email as i need to ask afew questions
so i can finialise wiring and send it back
thanks
sideshow
my website
www.sideshowsperformancewiring.com.au
Old 09-08-2007, 05:38 AM
Sideshow, I will send you the loom on monday.
However, the plugs from the states have not yet turned up. Is there any reason why you can't make the loom with just wire tails for me to fit the connectors to?.
That's just the Neutral safety switch, the back up light sensor and the elec speedp plugs. In fact, is there any reason why these have to go to the ECU?.
I'm not running cruise control or fuel computers so why does the ECU want these inputs?.
The rest of the loom remains as required.
cheers
Old 09-08-2007, 05:50 AM
some of the wires from the main loom need to goto the etra plug on ecu which i supply
its much neater if i have the loom to mod cause some wires run to front of car
but i cut loom apart nd run wires to ecu or under dash so it looks neater
otherwise some pwer wires would run down left side of car to front of engine
the ecu reads the speed signal input then sends the sgnal up to dash
so its different to how it was originally set up
i can wait till u get the plugs theres no rush just thought i would see how things are going
there is no neut safety switch for the l76 ecu the std t56 gearbox has a reverse lockout which stops reverse being selected when driving
but im sure the tremec doesnt have that problem
so the neut switch is not needed
anyway if your nto in a hurry dont worry lets just wait and send the stuff when u get it
i now have a workshop so i am bit more organised and get thru abit more work than i was when i was mobile
i hope to get more into the new holden wiring and stuff
as the l76 is an aussie engine and the next popular engine will be the l98
which i already have stuff for
so let us know how things are going and ill go along with that
thanks
sidey
my website
Old 09-08-2007, 06:25 AM
Sideshow, Thanks for that.
I understand what you are doing to the harness and that's great for me.
It was just that gearbox stuff which differs with mine so essentially it will only be the speedo sender in the gearbox that will go to the ECU.
Old 09-08-2007, 06:51 AM
no probs
im in no rush just when yr ready
my website
Old 09-08-2007, 03:45 PM
schipps's Avatar
Default Questions???
Jim,
What do you need to know?
regards
Mick
Schipps
Old 09-08-2007, 06:42 PM
Oopsy, I forgot to ask.
Jim, what size approx. is the little fuse box you will supply with the harness?.
I just planning on where I am going to put it.
Cheers mate
Old 09-08-2007, 11:46 PM
im tryin to find a small fusebox that uses the newer small style blade fuses
see how i go ill let u know
my website
