Old 10-07-2007, 02:16 AM
Cobra Make, Engine: Classic Revival Kobra,LS7 427
Default studs
Does any one know the size and thread of Jag XJ6 series 2 and Au Ford studs?
Old 10-07-2007, 02:19 AM
Aussie Mike's Avatar
Both the Ford rear and the jag front run standard 1/2" studs with the same thread pitch.
Mike Murphy
Melbourne Australia
Old 10-07-2007, 02:24 AM
Are They imperial?
Old 10-07-2007, 02:38 AM
Yes, they are 1/2" so I guess they are imperial. Ford have kept the same 4 1/2" PCD and 1/2" stud size since the XR Falcon I believe. Very early Falcons XP XM etc ran a different PCD.
Jag have also kept the same 4 3/4" PCD and stud size for ever as well. Holden used to run this spec as well till they switched to a metric equivalent (120mm PCD) on the Commodore.
Mike Murphy
Melbourne Australia
Old 10-07-2007, 04:03 AM
I think the Jag is 4 3/4 inch, which is 120.65mm...
Old 10-07-2007, 04:20 AM
Sorry, yes you're right Bobby. I got my maths wrong. Jag is 4.75" and Ford is 4.5" PCD. Holden knocked off the 0.65mm to make it 120mm when the Commodore came out.
I've edited my original post.
Mike Murphy
Melbourne Australia
Old 10-08-2007, 04:30 AM
BMK's Avatar
BMK BMK is offline
alffie,
Studs - I bet the 105 views were mostly from the little ladies who thought you were talking about those other studs....
Bernie Knight
Rate This Thread:
