Old 07-05-2008, 02:03 PM
Cobra Make, Engine: Factory Five, LSx Block
Send a message via ICQ to Tails Send a message via AIM to Tails Send a message via MSN to Tails Send a message via Yahoo to Tails
Nice congrats on the milestone..
Tails
Daniel
FFR MKIII Roadster Complete Kit, 3-Link, GM LSx Block, T56.
Build Pictures
Build Blog
First Start
Gokart
Let's Take A Ride
Old 07-05-2008, 05:26 PM
Congratulations...
Music to the ears!!!
Old 07-05-2008, 11:12 PM
ls1 Ac Cobra's Avatar
Cobra Make, Engine: Classic Revival ls1 supercharged 6 speed
Well done Andrew how good does it feel when you hear it run for the first time. Now all you will think about is when can I drive it.
Old 07-06-2008, 12:42 AM
Well...Andrew started it for the first and second time yesterday.
What's the bet he started it today?, more than once too.
I'll even make a bet he let it run longer today.
Old 07-06-2008, 01:39 AM
Default Well done
Great video. A bright day for a darksider
Richard
Old 07-06-2008, 02:24 AM
Tenrocca's Avatar
My ears are ringing......better build those pipes
Ironing out a few bugs today (well one at least) - engine check light was on, but hooking up the O2's fixed that - looks like the tuner got everything he needed to. Tachs not working, but that seems a common problem (without a definative solution??) - fixed a few minor awater leaks....still grinning
Old 07-06-2008, 02:25 AM
Gav's Avatar
Gav Gav is offline
Well done Andrew,
lawn mower my arse!!
Powered by Cu
Old 07-06-2008, 02:50 AM
Andrew, I wonder if this thread helps with your tacho problem.
LS1 VDO Tach
Old 07-06-2008, 02:57 AM
Tenrocca's Avatar
LS1 VDO Tach
Thanks Les - Im not getting anything (just a blip at start up) so may need to send it back to howards for a recal as Dale did.
Old 07-06-2008, 05:25 AM
Doubledip's Avatar
Send a message via ICQ to Doubledip
we have done a fair few of the L76's and depending on the tacho you are using there have been many ways they have been fixed.Some of the ways they have been fixed is having the tuner change the output in the ECU of the tacho signal or running a tacho booster (we have 3 types and depending on the type of tacho makes the choice of which booster to run).
Reason for the booster is cause the signal coming out of the ECU is very minimal as the holden dash was designed to take such a weak signal and work with it.. Majority of after market tacho's although designed to recieve an ECU weak signal still require a booster of some sort.
You can even get boosters that run of the coil trigger wire instead of using the ECU signal.
Because of these problems it is one of our first comments to guys we supply harnesses for that they make sure that the instrument supplier is will to take back/swap the gauges if they are not suitable for these type of engines.
Anyway good luck with it and if you need any help then let us know.
www.ultimateconversionwiring.com.au
_
Old 07-06-2008, 04:12 PM
Default Now that's going to hurt
Originally Posted by Gav View Post
Well done Andrew,
Will he need the whipper-snipper as well?
Old 07-06-2008, 04:48 PM
Leeroy's Avatar
Default Yipppeeeeeeeeeeee it breathes
Andrew
Fantastic news and a great milestone in your great build. Well done on the wiring
yourself as takes lots of patience and faith.
Glad to see the whole family shared your moment (Mizzi's also)
Leeroy
  #33 (permalink)
Old 07-06-2008, 06:03 PM
boxhead's Avatar
Congrates Andrew, it is a big moment in the build process.
How many more times have you gone to the shed and started it up just to hear it?
Cruising in 5th
  #34 (permalink)
Old 07-06-2008, 09:38 PM
Awesome stuff...
Good to see another Dark side machine taking shape!!!
  #35 (permalink)
Old 07-06-2008, 09:45 PM
Merv and Sharon's Avatar
All this "dark side" celebrating. We also have LPG. I am thinking that the day when we see diesel Cobras is not far off! Are there any out there?
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #36 (permalink)
Old 07-07-2008, 03:56 AM
boss290cobra's Avatar
nice one andrew finally now it will seem like you are getting some where ,cant wait till i crank over the FORD donk
damn these icv's :CRY
