Old 07-12-2008, 08:37 PM
Merv and Sharon's Avatar
Default A Couple of Engine Questions
In cleaning and (first) re-furbishing of my (coming) Ford 5.0L EFI motor I was going to replace many of the components (oil pump, alternator, water pump, starter motor and remove and blank off the existing fuel pump. The value covers will also be replaced.
Are there good sets of ARP bolts around to assist with this as I wasn't too keen on putting the old bolts back on?
Second, what is the best kind of gasket sealer to use on the supplied gaskets for water pump, oil pump and so on?
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 07-12-2008, 08:46 PM
Cobra Make, Engine: Classic Glass 302 Windsor
ARP have an external engine bolt kit which is resonably priced and covers all the required bolts to assembe the engine. These are available in stainless steel or moly, hex head or 12 point. As for gasket glue I prefer pocktite gasket eliminator. A hint for the front cover if you are putting a new one on prior to doing this coat the inside of the water passage with Blue max (ultra blue) silicone as a barrier against corrosion.
Old 07-13-2008, 02:45 AM
Loctite gasket eliminator is the go ! (It's the purple stuff)Try Summit Racing for ARP bolt kits.
Smithy
Old 07-13-2008, 06:00 PM
The part numbers for the bolt kits are as follows
ARP554-9801 Chrome moly black oxide hex head
ARP554-9701 Chrome moly black oxide 12 point head
ARP554-9601 Stainless 300 hex head
ARP554-9501 Stainless 300 12 point head
These are for a 289/302 small block only
Old 07-13-2008, 07:08 PM
Mando's Avatar
I used the Stainless 12 point head kit on my motor. If you use stainless make sure you smear a little Loktite antiseize on the thread of every bolt. Dont take any chances.
Regards.
Mando
Old 07-14-2008, 10:54 PM
Fantastic and thanks guys!
Merv
Thanks also to Optus!
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 07-17-2008, 01:17 AM
Have ordered a stainless ARP full set and the motor is 2 weeks away! It is a 1992 Mustang 302 EFI. Keen to see what shape it is in. In the meantime, off to Groote Eylandt for some fish bothering.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 07-17-2008, 02:10 AM
boxhead's Avatar
Dont fall in the drink, the lizards are big out that way.
Cruising in 5th
