questions
- » Blogs
- » Image Gallery
million posts!
| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
07-31-2008, 01:33 AM
NSW
My Dash is finished.
Originally, the dash was designed with the glove box lid fitting precisely into the glove box opening. When it was finished, I didn't like the look at all, especially the exposed hinges. I then spotted Phil Mizzi's car at my trimmers and really liked the look of his glove box lid fit and decided to adopt the same design. Unfortunately, it meant re-designing the hinge setup, making the lid larger to fit over the opening instead of inside it and stripping the leather and padding back from that side of the dash.
The first photo is the original design which was scrapped.
The next photo is the new design which I received back from the trimmers today and which will be going into the car. I'm pretty happy with the look.
Advertising
07-31-2008, 02:39 AM
AUS
Baz, that's amazing the difference. It certainly looks a lot better to me.
Really credit to you. You certainly have an eye for detail.
07-31-2008, 02:47 AM
VIC
That looks great Baz, noticeable improvement!
What's that slot to the left of the toggle switches in the lower centre section? Hidden cassette deck?
07-31-2008, 03:00 AM
VIC
That looks 100% better Baz, really finishes it off nicely.
Mike Murphy
Melbourne Australia
07-31-2008, 03:08 AM
NSW
No Sambo. It's a little gold plaque to remind me to respect my anticipated power to weight ratio.
Thanks for the kind thoughts Craig and Sambo.
Can't wait now to get the car finished. Am installing an XER273HR Hydraulic Roller Comp Cam with dual Crane Valve Springs into my LS2. That will be the only modification to the engine at this stage. Can anyone tell me what percentage increase in KW or BHP I can expect from the stock 307kw - 412bhp?
Baz
07-31-2008, 04:07 AM
QLD
Much better Baz...looks great mate.
07-31-2008, 04:12 AM
Huge improvement, great finish.
Regards.
Mando
07-31-2008, 05:09 AM
NSW
Looks great Baz,
That badge brings back memories , my wife told me that just after we got married, on our honeymoon actually
07-31-2008, 05:58 AM
Vic
Hp
Baz,
I have the same engine (L76) WITH 307kw...
I recently purchased a Cam and Head package, they were saying to me 50HP for the Cam and the same for the heads.......
STIFFY
07-31-2008, 05:59 AM
Qld
we finally gotcorrect engine loom from holden
i guess they didnt tell u how complicated the tip tronic set is
they sent u the l76 auto harness its usesles on an l98 titronic
the tip tronic works thru the bcm and then the bcm talks to the pim
then the pim talks to the engine ecu
the tip tornic gbox has the auto ecu inside of the gbox
we spoke to holden and u cannot buy a new bcm for the ve at this stage
and the bcm has very fancy plugs on it so i guess we willneed to buy the dash harness which has the bcm plugs
but i pressume it wont be available to buy yet either
another problem holden didnt tell u is that the ve will not start if the factory stereo is not there so the enigne ecu needs to have security disabled
but we are not sure what tune the guys at holden put in the ecu
like 99% of people out there guys at holden have no idea and did not do their research properly and atleast should have told u these things
but not to worry we are slowly getting thru this and asking alot of questions to our contacts at our holden shop and will be looking for a crashed ve to try get the parts that holden cant supply yet
another thing is the engine and auto has to be all plugged in together then a factory tune be flashed to both the auto and the engine ecu then the enine ecu needs to have the security turned off
so the ecu they supplied was a waste of time removing security cause it might have to be done again if we have to flash both ecus with a holden tune
anyway yr in better hands then those guys at holden down in melb where u got enigne
so hope to have all the stuff in next few months
so not to worry
07-31-2008, 03:30 PM
NSW
so not to worry
Thanks Jim,
I was feeling really great this morning until I came in and opened this thread. It's a little like getting the really bad news from your Oncology Doctor.
Not to worry. I know you and Neil will sort it out, but your comment about having the 'all the stuff in the next few months' worries me a bit. I was hoping to be going through rego then.
Baz.
07-31-2008, 04:23 PM
Qld
ok sorry i didnt know what time limt u were on
we can start sorting things out now
our main problem is holden just dont have parts available that we need
but will try them again and ask them to try harder and see which way to go
but if anyone knows of a written off ve comm them we might be abe to raid parts off it
this is not like yr ordinary l98 or l76 auto
which we have done alot off without any probs
anyway ill keep u posted
07-31-2008, 06:13 PM
NSW
Bugga Baz - thats what happens when you break new ground with your engine\box combo. Sounds like your in good hands though.
Sidey - just curious, is the L76\L98 manual wiring the same? I know the tunes are different but not sure if they change any of the pin assignments.
07-31-2008, 10:38 PM
NSW
Mate,
I will leave that up to Jim to answer. He's the expert.
While you are there Jim, I spoke to Neil about the tiny hiccups which are occurring with my 6L80E transmission this morning and he is getting onto his contact at Holden in Ballarat.
Baz
08-01-2008, 02:13 AM
Qld
yer l98 and l76 manual are siilar
only prob with bazs is that is it tip tronic
tiptronic signals from shifter goes to the bcm not to the engine ecu
tip trpnic auto gbox has the ecu inside the auto
its very complicated but not hard
we can buy a ve bcm and we can buy the harness that has the bcm plugs
only prob is tht its around 1100 bucks for for both so 550 each
i spoke to neil and i spoke ti guy at ballarat and said call me back
but the holden guys have not called me back so at moment i dont give a rats about ballarat i recon they should have had some info back to us in one day but i gues they dont care as much as others
anyway enough rubbishing them
i can get the parts needed
then we need reprogram the bcm
then we need to reprogram the engine and transmission ecu
my problem is i wont pay for the bcm and harness myself cause if all this doesnt work
i wont be stuck with the parts
i want ballarat to supply the parts and if they dont work then im not stuck with a 1100 buck bill
i am 99% sure this should all work by talking to people i know
all we can do is hopefully ballarat will getback to us
or u can say ok buy the bcm and tune and get all wiring done then we have to take car to a holden dealership to get a tune flashed in it
thats if the auto has no tune wch we dont know and will never know untill we power it all up
if its a new auto then i guess it has n tune
once its all powered up and std holden ve tiptronic tune we can then remove the vats security frm the engine ecu and it should start
but so far its looking like we should have no probs
08-06-2008, 02:26 AM
Qld
hey baz got some good news
we found another way to do the tiptronic which we dont need a bcm or harness
but the ecu that holden supplied and tuned is probably useless
as it hasanaussie tune which is no good for what we want
so basically we will use our tune and our ecu so its linked to my laptop and we can flash the engine and auto ecu all at once using my software and will not need extra people to come and flash theecu
also holden have not rung me back so they can f off as far as i care
but least now we should get it all workin ok
08-06-2008, 03:32 PM
NSW
Sounds good to me Jim. Thanks for everything.
Baz
08-11-2008, 01:22 AM
Qld
we are going to buy new tool to start flashing new blank ecus
since the guys at holden dont know much about the very late complicated stuff
we will be bypassing them and doing it ourselves
so beware anyone who buys an ecu from them heheheh
will start pulling yr loom apart this week so it will be ready for when i go to neils to do the rest
ill give him the ecu u got from holden so u can send it back if they have any problems get them to call me so i can abuse them just kidding
the slackos still havnt called back
hehehehehehehehe
08-11-2008, 03:39 PM
NSW
hehehehehehehehe
Jim,
My dreams are in your hands.
Baz
