questions
- » Blogs
- » Image Gallery
million posts!
| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
10-04-2008, 05:13 PM
Qld
Cobra Make, Engine: Evans kit, 6 litre, 6 speed, Jag F/R,
Underbody exhaust.
Took the cobra for a trailer ride recently to brisbane.
An old mate directed me to Custom Exhaust Systems in Meadowbook. Without any prior warning or booking I was very lucky that Trevor and his team were able to help me out with a nice underbody system.
Nice mandrel bent headers, though 2 megaflow cats, x-piped centre section and a couple of lukeys at the back.
Trevor even missed his saturday racing to help finish the system.
I have some welding and mounting to finalise, but am extremely happy with the work CES did.
Edit, pics didnt work, heres a link to the exhaust pic page
http://www.comdotau.com/gall/index.p...obra%20Exhaust
Missed my Cobra budget by thaaaat much.
Ya get that on big jobs.
Advertising
10-04-2008, 05:34 PM
QLD
Very nice work it seems! I have spoken to Kevin as well and will hopefully be visiting him next month! No clearance problems at the back?
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
10-04-2008, 06:56 PM
QLD
Woops - Trevor!
M
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
10-04-2008, 07:09 PM
Ca.
Those cat's seem a little close to the trans. Might it get a little hot in there?
Terry
10-05-2008, 12:52 AM
VIC
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
C'mon Terry, its a cobra, like there's enough room to be choosy about where we put the cat's
Cameron
10-05-2008, 01:11 AM
Qld
Merv
Well Merv,
If I can offer any helpful advice for the pending visit;
Trevor and Leslie are both really nice people.
If you rock up from nowhere and get a job done at zero notice like me you'll most probably pay the "nil notice wanker" premium. Which is of course industry standard.
Trevor doesnt make you tea or coffee, you'll find the jug down on the back wall.
You will pay for the experience and after a few days will justify to yourself why it was worth it. Neat fit, attention to detail, snug but precise fits, tig welded joints.
As for clearance at the back, I will slightly flatten the pipes as they pass between the swing arm and axle, but there is really adequate clearance for a firmly sprung car.
I elected to just have the rear mandrel bends <> muffler joints only tack welded so I could rotate and adjust clearances when I get the rear wheels on. This is what happens when you are on a budget for time and dollars tho.
Also got some good advice on triangulating the chassis, modifying the diff base plate and engine mounts to prevent torque twist.
All in all, bang for your buck, good people, good people who know thier sh"t.
10-05-2008, 01:24 AM
QLD
Thanks for the good advice. I will give him plenty of notice. I plan on putting the motor and gearbox in over the next two weeks and Warwick Harrison is having some nice ceramic coated headers with O2 sensors made for us. I have the cats already. Thinking I will go for stainless from the cats on down. Then I can start the thing!
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
10-05-2008, 01:38 AM
Qld
Funnily enuff Cameron and Terry,
there is quite a bit of airflow and vacant landscape around the cats.
The guys got the cats in the right spot. The Evans kit has room for a C10 or similar huge tranny and the T56 Tremec looks anorexic in there.
I plan to narrow down the floor tunnel slightly and finish with a 3mm sheet Aluminium tunnel. This allows better fitting or seats and a handbrake in the Evans kit. Even after that there will be good airflow around the cats but I will even take care then and fit alum/ coated fire blanket or 3 mm Al sheets under the floor.. Its hot enuff out this way without unnderfloor heating.
10-05-2008, 09:32 AM
Ca.
Cameron, You are correct. There is not much room in these Cobras but frying a transmission with the cats would not be prefered  . They just looked real close in the picture.
Terry
10-05-2008, 10:30 PM
VIC
You make a good point Terry. Cats are a bugger to find space for. Does anybody know if it is advisable to get cats ceramic coated?
Cameron
10-05-2008, 10:51 PM
VIC
I reckon there would be enough airflow in there to keep most of the heat away from the trans whilst on the move. You could always install a heat shield between the cat and trans if it became a problem.
Mike Murphy
Melbourne Australia
10-05-2008, 11:30 PM
VIC
I think that process would also cover the elements inside and stop them from doing the catalytic conversion - rendering them useless.
(I spose if they're useless you can throw them away?)
LoBelly
10-05-2008, 11:41 PM
nt
Cobra Make, Engine: Classic Glass 302 Windsor
Getting the cats ceramic coated should not be a problem as the coating is sprayed on and not dipped so it shouldnt affect the inside.
