Old 12-13-2008, 05:57 PM
Jac Mac's Avatar
Smile Forget the Locker--fit a tru-trac unit.
As above, I have run both & would not bother with a locker again. Tru Trac is so easy to push around in the shop, nice progressive feel on the track, no click -click-click at roundabouts or anything like that to alarm you. Drive a similar car if you like with one fitted, you will be impressed.
Jac Mac
Old 12-13-2008, 08:05 PM
AC-460's Avatar
Thanks Jac Mac I'll do some more homework
Cheers Mark
Old 01-06-2009, 01:06 AM
750hp's Avatar
I would definitely recommend the TruTrac unit. DV from this forum (jeez, where's he at the moment?) was able to run wheels up launches at the track with his 31 spline TruTrac and it handled the abuse.
I have full spools in two of my cars - one of which was the Cobra - and they worked fine for me. Honestly it was fine to drive on the street, and not even a problem in the rain. Having said that, I hadn't set mine up for ultimate handling, so i know the Tru Trac would have been a better handling option. They just didn't make them in 35 spline at the time...
Craig
Old 01-09-2009, 07:48 PM
Tonkin NZ's Avatar
Cobra Make, Engine: Indigo Superformance MkIII. Ford 460, TKO600
Hi. I have a Superformance with a 460 and TKO600. It runs well throught to a Dana LSD 3.46:1.
For details on SPF2828 - click here
