November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-24-2009, 05:54 PM
Default Lsd
Gday guys
Do most of you guys use the lsd rear ends or is a non lsd rear end sufficent for a car that only going to be used as a weekend cruiser?
thanks.
Graeme
Old 02-24-2009, 06:03 PM
Originally Posted by whiteredblade View Post
Gday guys
You do not need a posi, or even an independent rear for that matter, for "gentle weekend cruising." BUT, if you start showing off and get on her hard over a bumpy, dusty, curvy road you'll want a fully independent limited slip rear to keep you on the road, not off.
Old 02-24-2009, 07:31 PM
boxhead's Avatar
For a weekend cruiser a non LSD will be all you need.
If you want to lay 2 black lines when taking of then you need the LSD
And if going drag racing you will want LSD.
Cruising in 5th
Old 02-24-2009, 07:37 PM
Nothing looks quite as stupid as a one-legged burn out -- unless you couple it with uncontrolled wheel hop.
Old 02-24-2009, 09:20 PM
LoBelly's Avatar
ditto
the single spinner might help you avoid finding that you're suddently pointing the wrong way
LB
Old 02-25-2009, 05:02 AM
acecob's Avatar
If your running a Ford power plant you definately need a LSD
as for the others a banjo will be sufficient
Old 02-25-2009, 05:47 AM
Originally Posted by LoBelly View Post
dthe single spinner might help you avoid finding that you're suddently pointing the wrong way
Or just pull four of the plug wires. That'll keep you rear end from coming out from under you as well.
Old 02-25-2009, 06:38 AM
Aussie Mike's Avatar
Some of those Ford blokes are on LSD I think
Mike Murphy
Melbourne Australia
Old 02-25-2009, 02:04 PM
schipps's Avatar
Default Why?
Acecob,
Aren't the words "Ford Power plant" an oxymoron???
Schipps
Old 02-25-2009, 05:20 PM
AC-460's Avatar
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
I'm just fitting a 9'' IRS and are using a Detroit True Trak it detects when one wheel loses traction and transmits the power to the other wheel. These things are the next step up from an LSD and not as irritating as a Detroit locker
Old 02-25-2009, 05:31 PM
AC-460's Avatar
This chev ford thing comes up all the time..... I reckon if shelby thought a chev engine was any good he would have put one in to start with..... Its like buying a ford car and putting a holden donk in it.....
My two bobs worth
Cheers Mark
Old 02-25-2009, 05:50 PM
We've hooked him Schipps, Now we've just got to reel him in
Mike Murphy
Melbourne Australia
Old 02-25-2009, 05:59 PM
WKB's Avatar
WKB WKB is offline
Cobra Make, Engine: Harrison Cobra, SC540 Roadster
I think Acecob used the right bait as he might have been the first one to hook a couple.
Old 02-25-2009, 06:17 PM
He got a couple of nibbles with that one. Mark took the big bite.
Mike Murphy
Melbourne Australia
Old 02-25-2009, 06:33 PM
AC-460's Avatar
You just gotta laugh fella's..... each to their own an enjoy it!!!!!
Old 02-25-2009, 06:35 PM
boxhead's Avatar
Mark has forgotten that Shelby went to Chev first and they knocked him back, so even the man who built these cars really wanted to put a chev in it, we simply carry out his wishes
Cruising in 5th
Old 02-25-2009, 06:52 PM
Don't you start Dave. This is how the Cold War started. Khrushchev and Eisenhower were arguing about who had the biggest A-Bomb
Mike Murphy
Melbourne Australia
Old 02-25-2009, 07:01 PM
And ...
It would appear there were a couple of chev powered AC Ace running around years before good ole Shel even thought of the cobra.
Called the CorVace .... see here.
CorVace Photos!
Old 02-25-2009, 08:15 PM
Oh to have fallen so far...
From one who was once one of the blue oval's staunchest most one eyed supporters. To have pointed out that the chev came first...
Les I humbly offer my Vader mask and cloak to you. You are now the master.
Mike Murphy
Melbourne Australia
Old 02-25-2009, 08:33 PM
Who me! .... never .... nope .... Not this lil fella.
Always been totally supportive and considerate when it came to those using alternate engines. (crosses fingers)
Don't want ya mask and cloak taa ... you remain the instigator and master of all things involving chevs in cobras.
