  #41 (permalink)
Old 03-21-2009, 06:17 AM
fkemmerer's Avatar
Cobra Make, Engine: ERA, FE BBF
Originally Posted by Mando View Post
Fkemmerer, fantastic build. Do you use screens or filters on your injection system? I followed your long post on your build and was wondering what the sensor on your tailshaft was for? By the way the log of your build and the quality you achieved was the best Ive ever seen bar none. I recommend anyone thats interested in seeing some AMAZING work find Fkemmerers build log on Clubcobra.
Regards.
Hi Mando,
Thanks for the nice comments. I do use screens. Here's a picture of them:
The sensor on the driveshaft is related to the electronic traction control system on the car. You can see the sensor in the following picture - it is the silver collar and associated sensor between the back of the driveshaft and the differential.
Here's a closeup picture before the driveshaft was installed:
The silver collar is a custom made piece that contains 2 equally spaced magnets at its edge. As the driveshaft rotates, these magnets fly by the sensor (the part with the wire comming out of it) and create a signal that the EFI computer can read as driveshaft RPM. This data is used by the computer to record speed and miles per gallon in the on-board data logger memory. The computer can also sense any sudden jumps in drieshaft RPM and will interpret these as the rear wheels slipping/tires spinning. When the computer detects this, it automatically removes ignition timing from the motor which reduces torque output and controls the tire spin. I have not yet had a chance to full set up this part of the system up but I plan to do so in spring. If it works well, it should help solve some of the tire spin/control issues that cobras with large, high torque engines are prone too.
- Fred
  #42 (permalink)
Old 03-21-2009, 07:25 AM
SoTxButler's Avatar
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
My 488" Dove
Russ
  #43 (permalink)
Old 03-21-2009, 10:43 AM
Hello SoTX Butler
I have sent you an email
Bruce
  #44 (permalink)
Old 03-21-2009, 05:54 PM
Mando's Avatar
Hi SoTX, really nice work. Are the 3 square aluminium containers for brake and clutch fluid? What is the tank in front of the motor for that looks like a milk urn? Ive never seen anything like it, it looks beautifully made.
Regards.
Mando
  #45 (permalink)
Old 03-21-2009, 06:51 PM
Cobra Make, Engine: Superformance (AUS 09 or SPF 2792) - LS7 427ci
Hi Mando,
My guess is that the "milk urn" looking tank is an oil reservior for a dry sump!
Regards....Paul
  #46 (permalink)
Old 03-21-2009, 07:11 PM
csx wnab's Avatar
Cobra Make, Engine: superformance/427 fe ford
this is a little thing i do in my spare time
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
  #47 (permalink)
Old 03-22-2009, 02:31 PM
SoTxButler's Avatar
Hi Mando,
Thanks for the nice words. The fluid reservoir is a Tilton billet reservoir. One is for the clutch and one each for the front and rear brake's master cylinders.
The tank is a Patterson dry sump tank. The engine is a dry sump side oiler.
Russ
