Old 04-03-2009, 01:08 AM
byroncobra's Avatar
Default Heater and scoop
Hi Fellas
A few questions if you will.
I'm pondering whether to put a heater in my car. Harrison no longer uses heat only a marine blower. Anyone not fitted one up here in Nthn NSW or Qld and regretted it? There's a few heaters around I think, do they need complicated valves to open/close water flow or is the flow continuous so do you just turn on the fan in the unit and warm air flows into the cockpit when needed?
I'm fiddling with fitting locks to doors and boot, all was going well until I moved to the bonnet which has not been fitted since the Windsor went in. The intake plenm and throttle body are offset to the drivers side so far that the cut out & scoop, which is yet to be fitted, won't allow the bonnet to be closed if positioned in the middle.
Any one else had this problem? Looking at later Harrisons', the engine sits lower in the chassis than mine and maybe this may not be an issue.
Greg
Greg
