Old 04-25-2009, 02:04 AM
Cobra Make, Engine: DE Type Cobra Ford Windsor 302, 5lt fuel injected. Ford front and rear. 9" lsd.
Default wiper motor and arms
I am looking at alternatives for a wiper motor and arms, I am thinking about trying a british Leyland Mini wiper motor and chrome arms ( only 2 ) any thoughts on this one please.
Cheers.
Damo.
Old 04-25-2009, 02:21 AM
stephen low's Avatar
If you go the old British version make sure you try and get new parts where possible, as the wear on the coil and gear parts can be high. That said the system seems to work ok.
A bloke near me used the standard fitting which the wipers attached to but modified the inside of these to allow solid rods to be fitted with adjustable couplings.
This is one of the harder bits to get right on a cobra and even with his rods and adjustments it wasn't easy to make work properly.
slowy
Old 04-25-2009, 06:14 AM
LT65's Avatar
Cobra Make, Engine: Harrison #77
Damo,
I used a combination of Mini and Landrover bits. Check with your engineer before going ahead with a two wiper system, I had it all nutted out then was told engineer will approve a 3 wiper system, but may or may not approve a 2 wiper system. I think it was a Range rover rear wiper motor that has the 110 deg gear wheel that works with the 3 wiper system, for the 2 wipers I think I worked out 125deg was needed. I found the rover wheel boxes worked a little better for me. I do have a surplus lucas wiper motor if you havent sourced one yet.
Lionel.
Old 04-25-2009, 12:01 PM
I used a system from an old triumpth I found down the back of a wreckers. It had the steel tubes and clamping wheel boxes. I only needed to buy a third wheel box and some new chrome trim rings. I made the extra tube out of copper pipe with a flare at each end.
Old 04-25-2009, 04:49 PM
I'd concur with talking with the engineer on number of wipers.
I thought I'd heard just after I got mine through engineering with three wipers that the requirement had been repealed and that you could build with two wipers again. Worth checking just to make the job easier at least.
I sourced a new lucas motor here in Melbourne, still not sure if it a direct copy or from the revamped Lucas company. Anyway thinking about the load a three wiper system would have on a motor designed for two I though it worth the expenditure.
Also bought new wheel boxes and sourced a longer jag drive coil to enable me to link all the three boxes properly.
Didn't know about the rover pin option and manually repositioned the drive pin to suit the sweep needed. My three blades get progressively shorter accross the screen but they don't look too silly and the system works.
slowy
Old 04-26-2009, 01:22 AM
Merv and Sharon's Avatar
The three wiper system with the Lucas or "Lucas type" wipers seems to have stood the test of time. It is worth thinking about a new set as they can wear out and are difficult to get at one the dash is in. There are heaps of diagrams and info on installation. There was an earlier post on this topic I believe.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 04-29-2009, 03:34 AM
martrogers's Avatar
Cobra Make, Engine: Homebush fibreglass
I used the motor from my Commodore donor car and built a slider mechanism to convert the rotary action to push-pull. The throw is adjustable by 2 bolts so that I can adjust to get the correct wiping angle.
I did this because:
1. Cheapo - part of the donor car.
2. Will always be cheap and easy to get replacement motor.
3. Plugged straight into the donor harness giving full functionality (variable speed etc).
Old 04-30-2009, 06:36 AM
Good idea ! Three wipers were to meet the RTA standard to cover a specified area in front of the driver...but they had to also clear an area to the left for vision as well
Old 04-30-2009, 06:56 AM
Tenrocca's Avatar
The engineer I am using (NSW) has advised me the rules have changed and now state the vehicle has to have "an effective wiper system". I have used a 2 wiper system which looks better in my opinion and puts less strain on the lucas motor which works pretty hard pushing 3 wipers from all accounts.
Old 04-30-2009, 08:12 PM
Aussie Mike's Avatar
I'm plumbing in my 2 wiper system at the moment. It's the standard lucas setup. I'll post some pics of the process.
Mike Murphy
Melbourne Australia
Old 04-30-2009, 09:59 PM
all this talk of wearing bits out, i gotta ask how often are you planning on driving in the rain the only time mine have been on is when i took it to transport for its inspection!! may be i should drive it more but with no soft top or any other protection it aint goin out in the rain, not to mention those extremly grippy bf goodrich tyres
Old 04-30-2009, 10:51 PM
The plan for mine, when I get it back, is to get a lot of use.
I do plan on having a soft top ready for our 4 seasons in one day weather and a heater - I'm just not going to harden the f@#* up, so there!!
slowy
Old 05-04-2009, 04:29 AM
Ross Smith's Avatar
Cobra Make, Engine: RMC 302 Windsor Supra 5 speed Jag Suspension
Hi Damo,
If you want a full kit of new parts, you can get them direct from the Staffords in the UK, there is also a lot of good info on Lucas wipers on this site.
http://www.s-v-c.co.uk/prod_wipers.html
Staffords also have an agent in Australia, Charlie Unwin 08 9470 2571
Ross
Old 05-05-2009, 06:13 AM
I was wondering about Chopper Reid's view on all this...
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 05-05-2009, 06:42 AM
sambo's Avatar
Ross, great site - thanks! Has anyone fitted xenon H4 headlights?
http://www.s-v-c.co.uk/prod/p700-tripod.html
Old 05-05-2009, 07:44 PM
Default Wipers and the Engineer......
Having recently passed engineering I know a bit about the wiper situation in Victoria
I had to have the complete wiper sweep test done (at considerable cost) might I add.
It consists of 3 views, A,B,C they all have a certain percentage of cover that needs to be obtained.
So if anyone requires a wiper sweep report for a Harrison Daytona Coupe let me know ...
STIFFY
Old 05-05-2009, 09:08 PM
Who made you do that Stiffness?
I'm sure Enkelmans told me when I was done with engineering the two blade wiper option was back.
Am equally sure Bernie at best just tested my widdling boys and wipers whilst he was brake testing.
He certainly didn't do any review, measurement or so forth in the factory, as I was there through the whole assessment process.
I guess they probably react to VicRoads specific issues and needs from time to time.
slowy
Old 05-06-2009, 12:35 AM
sambo's Avatar
Slowy, best not divulge the various "interpretations" that some engineers afford... the walls have eyes.
Old 05-06-2009, 12:44 AM
roger roger
vector victor
surely shirley!!
slowy
Old 05-06-2009, 01:15 AM
Tenrocca's Avatar
This appears to be the current ADR rule regarding wipers:
"24. WINDSCREEN WIPERS AND WASHERS
Every motor vehicle having a windscreen must be fitted with a powerdriven
windscreen wiping system. This provision does not apply to LA,
LB, LC, LD or unenclosed LEM vehicle categories.
Every motor vehicle having a windscreen wiping system must have a
windscreen washing system that can direct water on to the windscreen
within the area swept by the windscreen wiper.
The device or devices for operating the wipers and washer must be able
to be controlled by the driver in the normal driving position."
This page has links to all current (and past) ADR's:
http://www.infrastructure.gov.au/roa...dr_online.aspx
Sounds like you just have to have wipers you can operate from the drivers position. up to the engineer to decide if its effective I guess, but certainly no mention of percentage area swept or the like. As I keep telling my Year 7's....google is your friend
