January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 04-27-2009, 06:17 PM
boxhead's Avatar
Default Reverse lockout T56
Hello everyone.
Last night I reassembled my selector assy with a modified selector hub assy, so it has the detent for reverse lockout.
I tested after refitting and found the reverse lockout is working correctly (ie can not select reverse by mistake), but I have now discovered that the solenoid is not pulling itself in either.
To the guys who might know, is this solenoid 12v drive or is it 5v?
I will be attempting to make it work correctly through the ecu, but I need to make sure the car is driveable (forward and backward) by sunday 10th May, so was thinking if worse case I might have to wire in a switch to select reverse and drive the solenoid.
Did not want to do this if the solenoid is 5v through fear of burning it out.
Cruising in 5th
Old 04-28-2009, 02:00 AM
gjkrv8's Avatar
Hi Dave,
According to my PCM Manual it looks like 12V.
Rgds
Gregg
Old 04-28-2009, 03:05 AM
LT65's Avatar
Cobra Make, Engine: Harrison #77
Boxhead,
Just looked at my manual and it is 12v in the test proceedures it refers to battery voltage should be seen at J2 pin44 when solenoid off.
Lionel.
Old 04-29-2009, 06:48 PM
boxhead's Avatar
Thanks guys, yep between looking at the manual when I got home and conversations with another darkside member, We managed to figure it out.
Yes the ecu is earth switching for the solenoid, and where my problem lay was that I did not have the power lead to the solenoid connected to the EFI relay, Once I traced this in the harness, the problem was found and fixed.
Cruising in 5th
