Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
February 2026
Old 08-26-2010, 09:54 AM
ndpace's Avatar
Cobra Make, Engine: B&B with Motorsport Crate 302
Default clutch/ignition interlock
Is there a standard way to make it so the car can not start in gear?
In modern production cars you have to have the clutch pressed in to start it, is that the easies way? How can that be done?
Thanks, Jim
2020 Shelby GT500
93 Mustang Cobra
66 B&B Cobra
67 Mustang Coupe
63 T-bird Convert
47 Fordor Flathead
01 F350 Crew Cab V10
Old 08-26-2010, 10:02 AM
Blittleton's Avatar
CC Member / Sponsor
Here is a nice little article on one of these switches.
http://www.fordmuscleforums.com/tran...ed-switch.html
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
Old 08-26-2010, 10:04 AM
Cobra Make, Engine: SPF 2592, Shelby alum. 527
If you have a Tremec transmission, they have a neutral switch that can be wired in series with the starter circuit, or you can install a switch on the clutch pedal (similar to a mechanical brake light switch) that can be wired in series with the starter circuit.
Rodger
Display Modes
