10-09-2011, 08:57 AM
IT
Cobra Make, Engine: cobra
sway bar
hi, my name is Norberto and i write from Italy. On march i bought a cobra from colorado. The cars is assembled with your parts. Now i want an information. In the front and the rear aren't installed the sway bar. Is possible instal they? because the car go left and right very pleasantly.
Regards, Norberto
10-09-2011, 11:02 PM
CO
Your english is much better than my Italian, but it sounds like you're having trouble with handeling. What brand of Cobra do you have?
These cars generally do not need sway bars for street driving.
The first thing to do is check for any broken parts, or loose parts.
Then check for ride height and balance. What kind of front suspension do you have? If you have coil over shocks, it's going to be easier. Seperate springs and shocks can be much more difficult.
After that, check the alignment - cast, camber, and toe in.
Once those are in proper specifications, the car should handle a lot better.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
10-12-2011, 10:56 AM
IT
Hi Bob,
it is made from B&B Manufactor. Can i send you some photos about front and rear sospention?
Regards, Norberto
10-12-2011, 11:28 AM
UT
Cobra Make, Engine: Factory Five MK4 427 roadster
10-12-2011, 11:42 AM
Just a front sway bar will make a huge difference to the handling ,especially that "wandering" feeling.The rear sway bar is nice but not necessary for the street.
10-12-2011, 12:02 PM
OK
Lets see how this translates?
Ho optato per un 1 "(2,54 mm) ondeggiano bar di fronte al mio B & B circa 8 anni fa. Fa una grande differenza nella gestione della vettura. Barra di oscillazione posteriore non ha aiutato tanto. Tassi di primavera per le corse su strada (600 Lbs Lbs frontale e 400 molle posteriori) sembrano funzionare abbastanza bene. ho anche sostituito il controllo degli armamenti posteriore superiore e inferiore con la parte posteriore STEDA superiore / braccio di controllo inferiore. Ricevi alcune scale e ottenere la vostra auto in equilibrio e che sarą di grande aiuto. i anche spostato la mia batteria verso l'angolo posteriore destro del mio tronco e abbassato la cella a combustibile per aiutare con centro di gravitą.
Good Luck,
Clois
I opted for a 1" (2.54 mm) FRONT sway bar on my B&B about 8 years ago. It makes a huge difference in the handling of the car. Rear sway bar did not help as much. Spring rates for road racing (600 Lbs front and 400 Lbs rear springs) seem to work pretty well. I also replaced the rear upper and lower control arms with the Steda rear upper/lower control arms. Get some scales and get your car in balance and that will help a lot. I also moved my battery to the right rear corner of my trunk and lowered my fuel cell to help with center of gravity.
Good Luck,
Clois
"Let's roll"
"Be part of Something Good
10-13-2011, 05:41 AM
OK
Norbert,
Did this help?
Fatto questo aiuto?
"Let's roll"
11-06-2011, 11:17 AM
IT
i didn't stay at home in these periods. now i return home. in this day i will contact B&B. thanks a lot for your answer.
regards, Norberto
11-28-2011, 11:23 AM
IT
Hi Clois, and thanks a lot for your answer. But in this period I didn't stay at home much time because i am out for work. Can you send some photos about your front and rear sospension? this is my e-mail snake34@alice.it.
Regards, Norberto
